Cub 1450 Engine runs for 30/45 seconds
   / Cub 1450 Engine runs for 30/45 seconds
It's fixed,,,,, after checking the gas tank I found a fuel filter in the bottom of the tank that was callapsed and dirty so I thought for sure this was my problem . I cleaned it and put it back in the outlet at the bottom of the fuel tank. I put it all back together and started it up and after running for about 40 seconds it shut off just as before, I couldn't beleve it so I decided to clean the fuel line that goes from the botton of fuel tank to carb and cleaned it and that was the problem as I got either red rust or red dirt out of the line so I blew out the carb and put it back on and started it up and now it runs good . Thanks a lot to you all for your help , I really appreciate it.:)
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
