Cruise control self install
/ Cruise control self install #1
Doughknob
ohio
Deere X500, Bobcat CT4045
Installed Bobcat’s cruise control kit last week. Was a breeze to do and it works great. I can set it and stand up while traversing the hay field like old days on the geared tractors!
/ Cruise control self install #2
Would be nice to have a cruise control where the MPH could be preset and held reasonably close for chores such as fertilizing and spraying.
/ Cruise control self install #4
Is it plug and play? Or is there more to it?
Plug and play. I installed mine too..they only thing that did wrong with the kit is the plug can be installed either way on the switch, so I initially had mine backwards. Off was on, and on was off.
Comes with all the relays, and the tractor already has the harness that the kit connects to. Took maybe 10-15 mins.
/ Cruise control self install #5
I feel like it holds the speed pretty steady... do you have it and a different experience with yours?
/ Cruise control self install #6
You can stand up??? Did you disable the seat sensor? Lol.
/ Cruise control self install #7
Awesome. 👍
Oh Yes! That is one of the first things i did. I hate those stupid things.
/ Cruise control self install #10
My tractor holds a steady speed when the cruise control lever is engaged. What I'm saying, though, is that an automotive type cruise control where the speed can be preset would be helpful on a tractor doing seeding, fertilizing and spraying type jobs. For example, one has found that application rate is correct when the engine RPM is at 1250 and the ground speed is at 2.6 MPH so presetting the 2.6 MPH.
Even just an accurate speedometer on a subcompact tractor would be handy just like on the larger farm tractors.
/ Cruise control self install #11
Oh yeah I hear ya.
And yeah.... if I didn't have 3 young girls (7, 5 & 3) I'd probably disable my seat sensor too. But while they're still young and possibly outside while I'm doing tractor work, I figure maybe its safer to keep it on in case I have to jump off for some emergency or maybe if they're riding with me.
/ Cruise control self install #12
On my CT2025 HST it was easy to install, except the steering wheel needed to come off. It does not work in reverse, it literally is an electro magnet that holds the forward pedal in place.
Caterpillar 16G Motor Grader Parts and Service Manuals (A63117)
Caterpillar 16G...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
PALLET OF MISC 3/4" PVC PIPE, MISC FITTINGS & PART (A64281)
PALLET OF MISC...
