Cruise control self install
   / Cruise control self install #1
Doughknob
ohio
Deere X500, Bobcat CT4045
Installed Bobcat’s cruise control kit last week. Was a breeze to do and it works great. I can set it and stand up while traversing the hay field like old days on the geared tractors!
   / Cruise control self install #2
Would be nice to have a cruise control where the MPH could be preset and held reasonably close for chores such as fertilizing and spraying.
   / Cruise control self install #3
Is it plug and play? Or is there more to it?
   / Cruise control self install #4
Plug and play. I installed mine too..they only thing that did wrong with the kit is the plug can be installed either way on the switch, so I initially had mine backwards. Off was on, and on was off.
Comes with all the relays, and the tractor already has the harness that the kit connects to. Took maybe 10-15 mins.
   / Cruise control self install #5
I feel like it holds the speed pretty steady... do you have it and a different experience with yours?
   / Cruise control self install #6
You can stand up??? Did you disable the seat sensor? Lol.
   / Cruise control self install #7
Awesome. 👍
Oh Yes! That is one of the first things i did. I hate those stupid things.
   / Cruise control self install #10
My tractor holds a steady speed when the cruise control lever is engaged. What I'm saying, though, is that an automotive type cruise control where the speed can be preset would be helpful on a tractor doing seeding, fertilizing and spraying type jobs. For example, one has found that application rate is correct when the engine RPM is at 1250 and the ground speed is at 2.6 MPH so presetting the 2.6 MPH.
Even just an accurate speedometer on a subcompact tractor would be handy just like on the larger farm tractors.
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
6 FOOT UTILITY TRAILER WITH MOTOR (A55745)
6 FOOT UTILITY...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
