Cruise Control Option - PT425
   / Cruise Control Option - PT425 #1
TheBigHeadKid
Northern NY
Power-Trac 425
Hello, I am a new PT425 owner. I picked up the whole trailer package with several attachments last week. I will post a few pictures of the new machine once I get them transfered.
Has anyone tried to install a proportional hydraulic valve in the treadle circuit. There is one pressure line that feeds the treadle and if that line was restricted flow wise it should set the maximum speed. You would then be able to depress the treadle all the way and only go so fast. I will be doing alot of mowing and keeping constant speed could be an issue. I mentioned it to Terry and Eddie and they both thought it might work. Anyone with thoughts??
Dave
   / Cruise Control Option - PT425 #2
Hi Dave,
Hearty congratulations, and wishing you lots of enjoyable hours with your 425!
What attachments did you get? Can't wait to see some pictures. We PTers just love pictures--- pictures of equipment and pictures of projects, too.
There was a thread here back in Jan which addressed hydraulic flow restrictors as applied to the FEL circuit {HERE} . I would think that the same principle could be applied to the treadle circuit. Take a look and see what you think.
   / Cruise Control Option - PT425 #3
Welcome aboard.
At the risk of proposing a somewhat less sexy modification, wouldn't a block under the right pedal do the same thing?
But will you need it? I've mowed a lot of hours with the 1845 without feeling I needed a cruise control or a speed limiter.
   / Cruise Control Option - PT425 #4
Welcome to the power trac owners group.
   / Cruise Control Option - PT425 #5
Welcome to TBN! /forums/images/graemlins/grin.gif
   / Cruise Control Option - PT425 #6
David,
Welcome to the TBN family.
I run my 425 very hard (300 hours first year) and after the initial discomfort of treadle pressure and the foot I have had no problems.
Will be interested in hearing from others on this issue.
PJ
   / Cruise Control Option - PT425 #7
I installed the restrictors in the lift circuit and am very satisfied with the results. Would I put them into the drive circuit? Nope. But the above mentioned "block of wood" solution would work very well and be easily modified. I have the treadle springs installed and now find driving my PT to be steady and true even using only the right foot. I think restricting that circuit would work but that there would be too many times that you wouldn't want it restricted.
Phil
2007 Ford F550 Superduty. 6.0 Powerstroke - 90k Miles (A56438)
2007 Ford F550...
2025 CE SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 CE SB05...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2022 CATERPILLAR 303.5CR EXCAVATOR (A60429)
2022 CATERPILLAR...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
