Cruise Control Option - PT425
   / Cruise Control Option - PT425 #1
TheBigHeadKid
Northern NY
Power-Trac 425
Hello, I am a new PT425 owner. I picked up the whole trailer package with several attachments last week. I will post a few pictures of the new machine once I get them transfered.
Has anyone tried to install a proportional hydraulic valve in the treadle circuit. There is one pressure line that feeds the treadle and if that line was restricted flow wise it should set the maximum speed. You would then be able to depress the treadle all the way and only go so fast. I will be doing alot of mowing and keeping constant speed could be an issue. I mentioned it to Terry and Eddie and they both thought it might work. Anyone with thoughts??
Dave
   / Cruise Control Option - PT425 #2
Hi Dave,
Hearty congratulations, and wishing you lots of enjoyable hours with your 425!
What attachments did you get? Can't wait to see some pictures. We PTers just love pictures--- pictures of equipment and pictures of projects, too.
There was a thread here back in Jan which addressed hydraulic flow restrictors as applied to the FEL circuit {HERE} . I would think that the same principle could be applied to the treadle circuit. Take a look and see what you think.
   / Cruise Control Option - PT425 #3
Welcome aboard.
At the risk of proposing a somewhat less sexy modification, wouldn't a block under the right pedal do the same thing?
But will you need it? I've mowed a lot of hours with the 1845 without feeling I needed a cruise control or a speed limiter.
   / Cruise Control Option - PT425 #4
Welcome to the power trac owners group.
   / Cruise Control Option - PT425 #6
David,
Welcome to the TBN family.
I run my 425 very hard (300 hours first year) and after the initial discomfort of treadle pressure and the foot I have had no problems.
Will be interested in hearing from others on this issue.
PJ
   / Cruise Control Option - PT425 #7
I installed the restrictors in the lift circuit and am very satisfied with the results. Would I put them into the drive circuit? Nope. But the above mentioned "block of wood" solution would work very well and be easily modified. I have the treadle springs installed and now find driving my PT to be steady and true even using only the right foot. I think restricting that circuit would work but that there would be too many times that you wouldn't want it restricted.
Phil
UNUSED FUTURE D-PDQ 47" LAND LEVELER (A57193)
UNUSED FUTURE...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2021 Chevrolet Silverado 2500 4x4 Crew Cab Knapheide Service Truck (A55852)
2021 Chevrolet...
FORD F550 SUPER DUTY SERVICE TRUCK (A57192)
FORD F550 SUPER...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
