Cross Drawbar ?
/ Cross Drawbar ? #1
tld
Boston, GA
JD 2025r
How would one use a cross drawbar?
/ Cross Drawbar ? #3
Tom...
You mean the horizontal drawbar with ends that hitch to the lower draft links? I have one of these and I've purchased 2 drawbar grab hooks that I place in one of the eleven holes on the Cat 1 drawbar. I use the drawbar to assist in dragging logs out of the woods. With larger logs, I evenly space the drawbar hooks apart on the drawbar, insert small length (5') transport chain onto the hooks, then I place my logging tongs in middle of transport chain and hitch logging tongs onto butt end of log, and finally I lift and drag. If logs are smaller and depending on terrain conditions, I may use only one drawbar hook. In this case I attach a tow chain onto drawbar grab hook (located in middle hole of the drawbar), wrap other end around butt end of log, then I lift and drag log.
...Bob
/ Cross Drawbar ? #4
Attached is a pic of a "cross drawbar", according to TSC., with a trailer hitch mounted.
/ Cross Drawbar ? #5
What keeps the bar from rolling when you hook your tralier up to it? I've seen the ones with a top link to keep the ball vertical. Just curious....
/ Cross Drawbar ? #6
I have that exact drawbar. Nothing keeps it from rolling unless you have something hooked up to it. I use mine to move my boat & RV around the yard, once the tongue is locked on the ball it won't roll much. I would like to weld something to connect it to the top link though.
/ Cross Drawbar ? #7
You can buy drawbar locking clips... see attached picture sample.
Kevin
/ Cross Drawbar ? #8
Gary, Thats why I did a little welding to one /forums/images/graemlins/cool.gif Every time I would try to put the ball under the trailer it would roll over. Stopped that problem for good! /forums/images/graemlins/grin.gif Attached is a photo of my handy work! /forums/images/graemlins/tongue.gif
/ Cross Drawbar ? #9
I like that looks very stable. I am just learning and all these little tricks will make my jump into the tractor world a bit better...Thank You
/ Cross Drawbar ? #10
One of my first welding class projects was making a cross drawbar shaped like a triangle. The result is pictured. I use a pinned slot to secure hitches to the bar. At the time, I never considered the receiver hitch arrangement so popular here on TBN. This system works well for me. I have 3 different hitch attachments that I can pin to the crossbar, and use them to tow a small garden dump cart, a chipper, an air compressor and my 16' trailer, as needed. Very useful, and it saves my back!
OkieG
/ Cross Drawbar ? #11
I use the drawbar like normde2001 posted with the drawbar lock that someone else posted............works great for me
/ Cross Drawbar ? #12
I don't see any problem with the bar rolling over....Let it. When the trailer tongue is hooked up, the latch keeps the bar straight.
/ Cross Drawbar ? #14
If towing a trailer a lot, the rolling motion can egg out the ball receiver on the trailer. I like the ones that hook up to the top link as well as the side arms.
/ Cross Drawbar ? #15
No grades in the nightschool version I took. But, it sure was a lot of fun. In fact, I took the course a second time, just because I was having such a great time. Oh, and I learned at least a little about welding, too. A VoTech welding course is highly recommended.
OkieG
/ Cross Drawbar ? #16
Von,
Your setup reminds me of THIS ONE . Does anyone here have one of the Bad River models or does anyone know if this company is still selling them? I don't know when I bookmarked their website, but just rediscovered it and could use one like that.
Thanks,
Terry
/ Cross Drawbar ? #17
That looks like a real nice one. Save a guy some time welding and scrounging parts. Thanks
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
Kubota SVL95-2S (A64126)
Kubota SVL95-2S...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2015 Dodge Journey SXT AWD SUV (A61574)
2015 Dodge Journey...
