Creating a Lake
/ Creating a Lake #761
I read where tilapia require 76 to 84 degree water. This was in a state paper on raising them commercially. What is the average annual temperature of the air at your locaton Eddie?
Large thermal masses tend to take on the average surface temperature of the earth at any given location. For me in south central Oklahoma it is 61 .x degrees F. There will be excursions above and below that temp but that will be the temp above and below which the temp swings. the max excursions away from the central tendancy may not be equal in both directions but will average over time toward the average surface temp. This assumes no special non-standard conditions.
I think I recall the bait the guys were using for tilapia. I think it was canned corn.
Patrick
/ Creating a Lake #763
EddieWalker said:
The stuff you see in that picture is just some floating debri. The wind blows it all to one area and it happened to be by the spillway, where I stood to take that picture.
The water is clearing up along the edges. I can see a few inches through it. Unlike the water in my small pond, this water has a differenent shade of brown to it and is constantly changing. It's real bad after a rain, but starts to clear up after sitting for awhile.
It's along the edge I'm talking about. Where the water seems to be only a few inches deep, it looks like you can see junk on the bottom. Like a big mud puddle that's been left alone for a while.
I'd strongly suspect that once you get some ground cover around that lake, it's going to be crystal clear. Just gorgeous!
/ Creating a Lake #764
Eddie,
Just wondering if you have calculated the runoff you get into the lake. Since this post I seem to look at lakes and ponds differently. Most built into a V of a hill, in the middle of a creek or branch, etc. Also with the rain lately all the lakes around the weekend place...just south of Palestine are full or running over. I noticed the ones going south on 19 to huntsville are also full. The lower area of the Trinity river area at Riverside even has water again. It's been dry for a couple years.
I guess is some of these places 1" of rain coule meen several inches in the pond...depending on how fast it came down and all, slower soaking or a dump and lots more run off.
Nice shot of the moon. Killed the deer hunting for the last weekend. I was able to track deer in my rye patch. Sometime after 11:00pm and before daylight.
Rob
/ Creating a Lake #765
OK Eddie your lake is full of water or close to it and we know that you aren't the type to sit back and watch the leaves fall from the trees, so let us know what part of the park you're working on now. We all enjoy your posts.
/ Creating a Lake #766
Eddie,
You might want to try some kissing fish in your pond.....:eek:
Don
/ Creating a Lake
Defective,
Compared to my muddy brown water in my small pond, the water is allot clearer in the lake. It also reflect the trees and the sky allot better too. But I have my doubts wether it will clear up any more, or if this is what I'll have.
Rob,
I went to Lowes today and bought a yard stick. At one time, I had a bunch of cheapy yard sticks that were free from home shows, but they seem to have walked off over the years. :rolleyes:
I put it in the ground at my overflow and waters edge, then layed down on the ground and adjusted the height by by best guestamate.
It reads that I'm 29 inches low. (see picture)
My watershed is really good in the areas I've cleared. The water just runs off the grass and dirt, with most of it making it to the lake.
There is a wooded area that is still very thick that might make up ten acres or so that sits just before the lake. This area doesn't seem to let hardly any water through it. This is where I should be getting the majority of my watershed, and from what I see in my drainage ditches, it's very minimal. With the wooded area, ther is another 20 t0 40 acres that should be giving me water that I'm not getting. Where is it going?
As I clear that wooded ten acres, I'll figure it out and do what I can to catch more water and direct it to the lake. I want every drop I can get!!! :D
Tom,
I've been putting pieces of concrete after my culverts to cut down on erosion. Not very interesting, just chunks of concrete. In fact, if you look at the picture, you will see my truck across the lake at one of my culverts. I'm putting sacks of readi mix in between the chuncks of concrete to eliminate any voids. I do a little at a time.
Othewise, I'm just pushing trees and brush into my burn pile with the dozer. I have a leaking cylinder on the backhoe that I'll pull apart this weekend and I bought some steel to make two more street lights for my entrance. Nothing very interesting.
Don,
Thank you for that picture. Steph is right here and she absolutely loved it!!!! I had to copy it to her art folder.
Everyone,
We're expecting a storm as early as tonight, but more likely the next two or three days. If it rains, I'll update the results from the rain guage and the yard stick, plus a few pictures of the lake.
Thank you,
Eddie
PS Did anybody think this thread would break 60,000 views? :eek:
/ Creating a Lake #769
Riprap after the culverts is a good idea, concrete in between the chunks likely isn't. Sharp edged pieces are most desired as they promote turbulence and take energy out of the flowing water. Smooth rocks are poor performers.
Here is some rip rap (riprap) info:
Riprap (also known as rip rap, shot rock or rock armour) is rock or other material used to stabilize shore. Riprap reduces water erosion by resisting the hydraulic attack and dissipating the energy of flowing water or waves. The shape of rock is important. Coarse, angular rock, usually made by crushing or blasting, or from scree, is more effective at ground reinforcement than round river rock. A correct mixture of aggregate size can also aid riprap's ability to create an interlocking structure.
Riprap is graded by size. A specified diameter will have fifty percent of the rock (by weight) larger and fifty percent smaller. The velocity of water flow is generally the determining factor for size of stone. Riprap varies in size from several centimeters to cast concrete shapes several meters across. The size and material will be specified by a civil engineer or local building code.
Riprap is often used in conjunction with a geotextile or in gabion baskets.
Filling in between with concrete smooths the path for water and lets it retain its energy instead of absorbing it through friction and turbulence. Where does the energy go when taken out of the water? The water and the riprap get heated just a little bit but not enough to seriously contribute to global warming.
Pat ;)
/ Creating a Lake #770
Pat,
If I understood Eddie's post, he is using sacks of Redimix that remain in the sack. It makes a good barrier and sets up quick. It is used all of the time in areas of California where streams flood roads due to excessive rain fall or an early snow melt. I have no idea of how long it lasts.
David B
/ Creating a Lake
Pat & David,
I need to take some pictures, but I'll try to be clearer on the rip rap.
When the water leaves the culvert, it's flowing very quickly, just like Pat said.
My concrete chunks are bigger than they should be. They are from the Rifle Range the Army built here in WWII. I own Rifle Range #4 of Camp Fannin. The concrete is busted up to various sizes. Some are hundreds of pounds and I can only move them with the hoe stick. Others are as small as tennis balls. I sort of created a path for the water to take on it's way to the pond.
The overall drop is about six feet right now and should be 4 feet when the lake is full. For most of the distance, it's fairly flat, then when it gets to the water, it drops of fairly quickly.
The problem I've noticed is the water gets under the concrete and starts digging channels. I dumped sacks of readi mix in between the spaces of the concrete to form a solid path for the water to travel. It's not smooth, but random with contours and high spots. The more water that goes through the culvert, the more it will be tumbled.
It's not that I planed that to happen, but that I wanted a rough looking path for the water to travel. In my mental picture, I see the grass groing to the edge of the concrete in random paterns and a semi natural look. If I ever find any rocks here, that's where I'll put them to make it look more natural.
The concrete sacks were to stop the water from taking out the soil as it entered the culvert. With massive downpours, I was loosing my soil around the entrance to the culvert. The 40lb sacks have dried nicely and are very solid. I no longer have any erosion problems there.
Thanks,
Eddie
/ Creating a Lake #772
Farwell said:
Pat,
If I understood Eddie's post, he is using sacks of Redimix that remain in the sack. It is used all of the time in areas of California where streams flood roads due to excessive rain fall or an early snow melt. I have no idea of how long it lasts.
David B
David, Well DU-UH, I just didn't get it! For absorbing the energy of the running water and preventing erosion I think the $ would be better spent with riprap as described in previous post for the reasons stated instead of buying concrete.
How long will a bag of concrete last that "goes off" in the bag? A very long time. A friend of mine and I wanted to grout in some large iron rings on piton like little posts set into crevices in a rock outcropping in the middle of a submerged volcanic crater at an island off the Pacific coast of Mexico.
We took a bag of READY CRETE wrapped up in a plastic garbage bag down with us when we sailed to that island. My buddy was in the dinghy and I was carying the crete to the starboard rail to hand it down. Everyone kept hollering at me to keep a hand under the bag so it wouldn't rip, so I did. One hand holding the top of the bag and one hand supporting it from below. as I leaned over the side of the plastic bag split open and the bag of crete barely missed the dinghy and my friend and went to the bottom in over 30 ft of ocean.
The next time we went we were even more careful and grouted in the rings which were so multiple yachts could easily use the rock for a bow mooring. When we snorkeled the little basin formed by the volcanic crater with one side missing (where we saied in and out) we always were reminded of the earlier thrilling episode because the sack of crete was still there. The paper sack was long since deteriorated and returned to the ecosystem but the pillow shaped sack of hardened crete was and still most likely is there. This was, I think, in the late 70's. We mused over what marine archeologists would make of it centuries from now.
A breeze fluttered my Bimini shade and an aluminum pole about 1 inch by 8 ft fell over the side (a retaining tie wasn't properly tied, ARGHHH,land lubbers!) and when I dove down to get it I found it next to the concrete pillow. This was maybe 10 years or more later. NO telling how long it might last.
Used as described downstream of a culvert, a lump of crete may be eroded over time if there is a sand and gravel transport in the flow of water but if there is no abrasive it coild last a very long time indeed. I have dug up fence posts that were in the ground over 50 years that had been set in concrete just dumped in the hole dry with no added water. Takes a while to cure but still does a decent job.
Pat
/ Creating a Lake
Sorry I didn't reply to your question earlier.
A non official observation is that April, we'll be in the 80's everyday and 60's every night. This will increase until July, when it will be in the 90's during the days and 70's at night. During the worse of the summer heat, we'll break 100 degrees. Usually it only happens a few times a year with high 90's being the average tempatures in August and September. By October it's real nice out again until December.
Guys on PondBoss that live in my area report there Talipia dying off then.
Thanks,
Eddie
/ Creating a Lake #774
Eddie, If tilapia are to be considered as an annual, how large must they be when you stock them to get adequate size in one season? Are they particularly fast growing in your climate?
Pat
/ Creating a Lake
I went down to the lake this morning to take these pictures of the culvert and how the water drains through it to the lake.
The first picture shows the water as it drains into my silt pit, fills up and then enters the culvert. You can see the concrete sacks that I put rebar through them. They are doing a great job of stoping erosion along the edges of the culvert.
In the background of that picture, you can see Lake Marabou. The island looking area is realy the brush that I left on the undewater island. It's two feet under water in this picture and all you see is the tops of the brush. I considered removing it, but decided to keep it as a level of shelter for my minnows when I put the fish in this spring. It's kind of ugly, but it will disapear in time.
The second picture shows the other side of the culvert with water flowing through it. I still need to do allot to make it pretty, but this picture should do a better job of explaining what I'm doing than I did with words.
The third picture shows it the same thing, but further back. You can see how the water is flowing over my readi mix/concrete chunk mixture, to where I haven't finished. I have allot more concrete in the area I'm burning, but it's too muddy to get the backhoe in there and get out again with two wheel drive.
Eddie
/ Creating a Lake #776
Eddie, A load of gravel the size of your fist and larger would sure help.
Pat
/ Creating a Lake
Pat
Hey Pat,
This is one of those things that I don't have a clue about. The guys who do this every year, have been studying the results and growth of thier bass compared to having Talipia and not hanving them. They feel the advantage is more than worthwhile.
My only hesitation is that I'm not putting bass in until this summer when I have a few spawns of fathead minnows. Then the bass will have plenty of forage to feed on.
I'll wait until I talk to the suppliers and decide at that time wether it's a good idea to put Talipia in this year, or wait until 2008.
Thanks,
Eddie
/ Creating a Lake #778
Eddie, I guess I get it now. You are interested in the tilapia as bass food. Tilapia are sold in stores for people to eat and I have been told that if you like bass you will like tilapia. My question was regarding the tilapia getting to a good pan fish size in one season. Not important if they are bass food.
I stocked my fathead minnows almost two years ago when I stocked 200 4 inch channel cats and haven't a clue how well they did. I guess I will either have to electrofish to get a representative sample or at least partially seine the pond with fine mesh to get an idea if they did OK.
Pat
/ Creating a Lake
We had an inch of water in my rain guage this morning, so Steph and I figured it would make the math real easy to see how much the water came up in the lake.
I was 29 inches low when I put the yardstick in the ground, and this morning, it reads that I'm 26 inches low.
One inch of rain, raised the lake three inches.
This is allot less than I expected. I have at least 20 acres of watershed, and it could be as much as twice that with my neighbors land above me. What I'm seeing is the areas that I've cleared the trees, I'm getting lots of water run off. The area with all the timber still on it isn't giving me hardly anything.
In my previous post, you can see all the water that I'm getting through my 15 inch culvert. That is the small one. I have an 18 inch culvert that should be handeling almost twice as much area, but it's not getting half the water the 15 inch culvert is.
I've walked the area and there is just no sign of runoff, erosion or any evidence of water running across the ground. All I can think of is that the ground is just sucking it all up. :confused:
Eddie
/ Creating a Lake #780
Eddie, I see the same effect. If it rains enough and frequently enough the ground will get wet enough to let water run off. If you do the measurement each time you will see variable results, not like having a paved parking lot for a water shed. Don't worry till the lake comes up less than the rain gage indicates.
Pat
2011 Ford F150 Pickup Truck (A64194)
2011 Ford F150...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2015 Ford F-550 4x4 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2015 Ford F-550...
