crazy idea
/ crazy idea #1
Mickey_Fx
Vancouver Wa.
Yanmar Fx24D, Cub 3204
As of late I've been thinking of the possibility of increasing the wheelbase on my tractor. The WB on the F series to a little too short for my liking. The frame extends fwd enough to permit a movement of about 1 ft without the need for any extension. From a quick look moving the front axle fwd doesn't look all that difficult and I'm thinking the biggest issue would be to extend the drive shaft and shaft-tube. Of course steering linkage would need to be addressed. At the slow speed these things run, I don't see any issues with the need to re-balance the shaft. For sure it would have to be jigged during the lengthening process to make sure the shaft stays straight.
Reason for the thought is steering is a little too quick and extending the WB would help reduce weight transfer with loads on the FEL. A ft extension would reduce weight transfer 33%.
Ever hear of anyone doing this and if so, what kinds of problems did they run into?
/ crazy idea #2
I don't know anyone that has done this with a tractor. You might just be the 1 st. best of luck
/ crazy idea #3
Saw one on the web once that they increased the wb, but it was a 2wd. Think they did it to put a deck under it?
/ crazy idea #4
Mickey,
Someone on here did it. I believe it was a YM1110D and he moved front axle assembly about a foot forward. (Think it was the same gent who got my rear hubs off my spare 1300D).
He moved the pivot + axle mounts and lengthend the drive shaft and pitman arm. It may have been for the same reason.
/ crazy idea #5
I remember the pictures of the one Mark is talking about. It was a smaller YM series tractor. It was a pretty straight forward job, with no real complications that i recall. I say do it !
/ crazy idea #8
Here is a link to the 1100. YM1110D
/ crazy idea #9
I have to admit I'd like to find one of these smaller machines so I could make it into a "super" garden tractor. I have a larger machine and it seems a little big for some things.
/ crazy idea #10
Ductape said:
Thats the one !
Wow! You guys have an excellent memory :).
OK Mickey, it's time for you to pioneer an F model extention. Love to see pictures, progress and test drive opinions.
Mark
/ crazy idea
Thanks for the replies guys. Looks like I'm not the only one that has had a crazy idea.
From my quick look it looks like I might have an easier time of it than was had on the YM1100. My front pivots mount from the bottom and it looks like the drive shaft is a straight in-line arrangements. From the initial look it appears I might be able to move fwd to point where I can use the current front pivot point as the rear pivot point. Does look like I need to see what if any problems exist with current position of the steering above the front differential.
Hey, Mark, haven't see a post from you in some time, here or on MU. Hope all is well
/ crazy idea #12
I am planning on doing the same thing in the near future also on my F16D.
Your F24 is very different from mine, but I'm still very interested.
/ crazy idea #13
Be sure to post pictures of the project. as far as the front drive shaft. There are places ( at least here) that will extend the shaft & balance it. The steering arm shouldn't be too hard to extend
/ crazy idea #14
Mickey, I have an extra FX front frame on the shelf, if you need any extra parts just come over, If can donate something to the project just ask
Ernies Imports
/ crazy idea
Hi Ernie,
Sorry I've not said Hi in awhile. That's a mighty nice offer you've made but that's the kind of guy you are. :)
If I undertake this mod, it will likely come a little later this yr or over the winter. Just too many things I need doing now.
Understand Chris has some sample labels/stickers for you. Said they look better than the sample you sent him. Hope this works out for the both of you.
