Crap my welder quit!
/ Crap my welder quit! #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
I was working on a few projects when my old Lincoln G8000 quit. When I try to strike an arc I get very weak sparks. Tried switching amp setting and polarity. It senses 120 volts when I plug in a trouble light by revving up the engine but won't light it up. I pulled off the cover nothing appears to be smoked. Any ideas? Think it's worth fixing?:(
M.D.
/ Crap my welder quit! #2
Naw, Just buy the one I have on Ebay now. Later, Nat
Tongue in cheek!!!!!!!!!!!!
/ Crap my welder quit! #3
I'm not familiar with that unit.. but look for problem areas.. like disconnected field or bias resistor wires.
I had an old miller D?? series welder.. diesel powered.. and there was a wire on a spade plug that would come off and no power to welder or plugs till it was fixed.
Soundguy
Thanx for the replies...well one anyway.:D
I checked the connections, cleaned the slip rings, no change. I posted the problem on a couple of welding boards and got a few more suggestions that I'll check tomorrow. I suspect something on the circuit board smoked. I asked for help on Lincoln's support site they said I should have a reply within two business days....we'll see. This has put a real crimp in my project schedule.
M.D.
Found a bad connection on the field bridge rectifier. Replaced one connector, cleaned and put dielectric grease on all the connections...It works!
Thanx for all the replies.
M.D.
/ Crap my welder quit! #6
Glad you got it fixed, and posted the solution. That might help someone else in the future if they have a similar problem.
/ Crap my welder quit! #7
I'm pretty sure that is what mine was.. field.. etc..
Soundguy
/ Crap my welder quit! #9
Pics would be nice, so folks know where to look. Glad your back in business.
Sorry I didn't take any pics when I had it opened up. I don't know if they'd be useful anyway unless somebody else has the same welder. I would suggest that if anyone else has the same problem they check and re-seat all connections in the welder.
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
John Deere 7000 4R Planter (A66408)
John Deere 7000 4R...
JOHN DEERE 5085E TRACTOR (A64277)
JOHN DEERE 5085E...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
