Crankshaft problem on Y395??
/ Crankshaft problem on Y395?? #1
Johnny P
Bronze Member
Brittany, France
"Shire badged" Jinma 284LE
Hello, Should read Y385!!!
Whilst using the tractor (Shire badged Jinma 28hp) a couple of days ago the engine developed a loud knocking noise. On investigation I found that if you got hold of the end of the crankshaft you can moved it backwards and forwards about 5-10mm. Any ideas what has happened and what I might need to put this right?
Thanks Johnny P
/ Crankshaft problem on Y395?? #2
You should have some endo. I believe most fall into the .005" to .010" range.
Loud knocking could be anything from a bad injector, to a con rod, to something hitting the fan. Any smoke from the exhaust?
Hello Bob,
Only smoke from exhaust is when I start it up. Don't like to leave it running in case of doing any possible damage. I tried loosening the injector connections on each cylinder in turn to see if that would cure the knocking but unfortunately it didn't. Funny, but earlier in the day the knocking started I had tightened up an injector hold down, I think you call it, as there had been slight blowing coming from the area where the injector goes into the block. Could be a coincidence.
Johnny P
/ Crankshaft problem on Y395?? #4
If you have 5-10 mm of end play in your crankshaft, something is definitely wrong there. As Bob noted, endplay should be no more than around .005" to .010" (0.13mm to 0.25mm) max. More than that and the crankshaft is floating around and whacking **** out of the sides of the journals, oil seals, etc.
I don't really know squat about these diesels, but on a gas engine I'd look at the front thrust washer. Could be something else on a diesel - I don't know if they even use thrust washers, but I'd think that they would.
I wouldn't run that engine until I knew more about what was going on or had some advice from a knowledgeable mechanic - which I certainly ain't! (grin) It shouldn't have that much end play in the crankshaft though, I'm certain of that.
/ Crankshaft problem on Y395?? #5
Possibly Broken crankshaft. I have seen this before in other non chinese engines. It will knock as you say, have huge endplay, and still run. You should drop the oil pan and investigate. I used to work at an engine remanufacturing facility in a previous life. So I have seen a lot of engine damage before.
/ Crankshaft problem on Y395?? #7
Could also be something as simple as just the flywheel comming loose. Pull the starter and see if you can wiggle the flywheel. If this is a small machine, you may just split it in two, and check it. Sounds like a lot of work, but really isn't. If it is the flywheel, some blue lock tight on the threads, and retorqueing should fix it up. Good Luck!
Hello,
Thanks for the info. Just started to remove the engine to investigate fully. It's all a new experience for me, this mechanicing lark. I will let you know how I go on.
Johnny P
Hello all,
Removed engine abd stripped down. The crankshaft has broken across one of the counterweights, Don't know why, maybe a fault in the casting!
Johnny P
/ Crankshaft problem on Y395?? #11
There are many contributing factors involved in broken crankshafts aside from bad forgings, which is highly unlikely, (crankshafts are not cast) which are not limited to unbalanced firing pressures from defective fuel injectors, mis-calibrated fuel injection pumps and worn piston rings/liners, defective/unbalanced clutch packs and flywheels, harmonics generated from the drive train, etc., etc.
/ Crankshaft problem on Y395?? #12
Hello all,
Johnny P
Could have been a fault casting or forging flaw but, I would be more concerned with the main bearing Housing Bores in the block to help determine the cause. The bearings wear pattern can tell a lot sometime.
If the line bore is off then the crankshaft main bearings will have excessive clearance that can and will cause the crank to jump / flop, (cranks don't like that). Piston connecting rods need to be checked / corrected when this happens. Crankshafts are so hard they are brittle.
Ronald
Ranch Hand Supply
/ Crankshaft problem on Y395?? #13
FYI: Crankshafts are not brittle, that's why they are forged from billet steel - to allow for the grain to follow through the webs and shaft line continuously. The journals are only hardened ~.050" to allow for ductility.
Ronald is correct about the line bore. Cranks will only tolerate so much repeated deflection before breaking.
I have never heard of an engine crankshaft made from cast iron - or cast steel for that matter.
/ Crankshaft problem on Y395?? #14
Remove crankshaft halfs. Box up and ship to "RRL Chinese Tractor Expert, Experienced Repair Remanufacture Facility" Wait several weeks for crankshaft to return repaired. Reinstall crankshaft. There is nothing Rob can't fix. :D
/ Crankshaft problem on Y395?? #15
I am not and engineer ........ just have spent my whole life trying to repair / maintain what engineers have designed (grease monkey).
I have just always assumed that diesel cranks had to pretty dang hard to be able to take the beating that a diesel puts on a crank and the ring tone it has when tapped on the end with a wrench ???.
But. I did do a Google search using ; Cast Iron Crankshafts , Cast Steel Crankshafts & Crankshafts are not brittle.
Ronald
Ranch Hand Supply
/ Crankshaft problem on Y395?? #16
Bob, what's the difference between billet steel, and cast steel?:confused:
/ Crankshaft problem on Y395?? #17
Ronald,
It was not my intention to seem condescending, I apologize. I too am a grease monkey.
IH3444,
Cast steel is solidified in a form (casting) and has no granular strength, whereas a billet is solidified as a bar, plate, etc., and forged into a shape by a press or rolled into various forms such as channels, angles, H-beams., etc. In a forging the grain of the steel follows the line of the forging from end-to-end and has much greater strength and resiliency. In both cases machining is still necessary to obtain dimensioning & finishes.
I shouldn't have made such a blanket statement that all crankshafts are forgings, as I know this to be true. There are light duty applications and extreme heavy duty segmented crankshafts where there are a lot of castings.
Hello,
Can any body supply the torque settings (Y385 engine) on the attached list,
Johnny P
(Hope the attachment works)
/ Crankshaft problem on Y395?? #20
Crankshafts have been forged for somewhat over a hundred years now, I think. I have a couple of old forging books that show the entire sequence for forging the things, not that I ever plan to do it.
I agree that probably all ordinary crankshafts are forged, and that forged is better than cast, but I wouldn't completely agree that the grain lines follow the forging - at least, not after heat treating. Once the steel has been taken above the A3 point, the grain of the steel becomes random again. It just can't help itself. :) Prior to normalizing though, the grain of the steel definitely does flow with the forging forces to some extent, depending on the manner and amount of forging. Open die forging generally will develop more grain flow while closed die forgings develop somewhat less. As a general rule - there are no real absolutes in forging work, in my experience.
It is my understanding from my metallurgist buddy at one of the biggest industrial forging joints in the country, that after forging the cranks are normalized to relieve stresses, then sent out for rough grinding. After rough grinding they are then induction hardened at the bearing and rod journals and finish ground to tolerance. The remainder of the crank is left in the normalized condition so that it can handle the stresses of reciprocation.
I haven't asked him what he thinks the reason is for a crank to break, but my guess would be a bad forging or bad line bore. During the forging process it is possible, though very unlikely, that a "cold shut" could get forged in at one of the transitions, resulting in a stress riser that later cracked under use. It is also possible that the original billet could have been flawed prior to forging, but that is usually caught by X-ray on QC check. In the US, anyway. :) It is also possible, and maybe even likely, that the crank was improperly machined after forging, leaving a sharp inside corner at a transition - this becomes another stress riser in use.
With all the possible ways that the crank might have been flawed, it still might well have performed fine if it was operating in a perfectly bored set of journals. But the least little bit of misalignment in the journals would set up stresses and harmonic vibrations that would cause it to self-destruct for sure. Even a perfect crank won't tolerate an out-of-line bearing line for too long.
That's my take on it, anyway. I'm **** sure no metallurgist, mechanic or engineer, just a blacksmith who's been around a bit, so you can take it for what it's worth. I'd definitely have the line bore checked, no matter what else you do. Put a new crank in a bad bore at your peril, in other words.
Rich
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2003 International 9200I (A53317)
2003 International...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2019 JCB 457 (A60462)
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
