Cranking JD H model HELP PLEASE
/ Cranking JD H model HELP PLEASE #1
jneville
DeWitt, VA
H JD
I have a Model H JD, serial# H61020 that was setting for years. The engine was seized but after soaking with transmission fluid and PB blaster it turns freely now. I am not getting any spark to the plugs. I am trying to figure out the fuel system also as I am sure the carbeurator is not working either. Any information on getting this tractor running would be greatly appreciated.
Thanks
/ Cranking JD H model HELP PLEASE #2
:welcome:
I'd first work on getting a spark. Track back through the system, to find out where the problem might be.
Is this hand crank? or electric start?
If no spark, I'd suspect bad plug wires or bad/dirty magneto.
Here is a link that may be helpful to you as well.
http://www.jd2cylservice.com/
/ Cranking JD H model HELP PLEASE #4
Ok, now to get spark. No need to do any carb work (other than know that fuel is reaching the carb) until you get spark.
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
2016 Ford Explorer (A66408)
2016 Ford Explorer...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
Skid Steer Trencher (A65640)
Skid Steer...
2015 Isuzu NPR HD Porta John Recovery & Cleaning Truck (A62613)
2015 Isuzu NPR HD...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
