Cranking JD H model HELP PLEASE
/ Cranking JD H model HELP PLEASE #1
jneville
DeWitt, VA
H JD
I have a Model H JD, serial# H61020 that was setting for years. The engine was seized but after soaking with transmission fluid and PB blaster it turns freely now. I am not getting any spark to the plugs. I am trying to figure out the fuel system also as I am sure the carbeurator is not working either. Any information on getting this tractor running would be greatly appreciated.
Thanks
/ Cranking JD H model HELP PLEASE #2
:welcome:
I'd first work on getting a spark. Track back through the system, to find out where the problem might be.
Is this hand crank? or electric start?
If no spark, I'd suspect bad plug wires or bad/dirty magneto.
Here is a link that may be helpful to you as well.
http://www.jd2cylservice.com/
/ Cranking JD H model HELP PLEASE #4
Ok, now to get spark. No need to do any carb work (other than know that fuel is reaching the carb) until you get spark.
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
New 20' Container (A62679)
New 20' Container...
40ft Shipping Container (A65583)
40ft Shipping...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
