CP3 & CP4 pumps
/ CP3 & CP4 pumps #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challengers: MT655E, MT555D, MT535B, Massey 7495, Krone 4x4 XC baler, 2-Kubota ZD1211’s, ‘20 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 38K trailer, Deere CX-15, 2 Pottinger Hay mowers, NH wheel rake, Claas 30’ tedder
had an enlightening conversation with a diesel mechanic with over 30 years rebuilding engines and about the CP3 & CP4 pumps.
He has only replaced 2 CP4’s in 200-450HP tractors, including AGCOs and CNH brands and only one was a failed pump. The same failure rate as CP3 pumps.
I asked him why so few CP4 failures in tractors and so many CP4s in pickups.
He said most of the newer large AG tractors running CP4s have a very high GPM gear pump running behind them pushing fuel into them, whereas a pickup only has a low GPM small electric lift pump pushing fuel into them.
Hes convinced the low gpm fuel lift pumps cause the CP4’s to fail. Large AG tractors rarely have CP4 failures.
/ CP3 & CP4 pumps #2
Don't the PSD trucks have a lower CP4 failure rate than the old Duramax and Cummins trucks that used to run them?
/ CP3 & CP4 pumps
I would think they have the same failure rates, but Ram has a higher replacement rate since they volunteered to replace ALL CP4 pumps at no charge.
Ford only replaced them when they failed, which is BS if you ask me. I don’t know what GM’s policy is.
I have no idea why a CP4 pump would last any longer in one brand or another unless it was backed up by a stronger lift pump.
/ CP3 & CP4 pumps #5
Ram had a couple of fires and they jumped in before a recall could be issued. For whatever reason their setup had a fire potential. A difference in the different brands could be the filtering and supply like you said.
i’m on at ford-truck and the other diesel truck forums and see these failures from time to time. I‘m on my 10th or 11th diesel superduty and have had minimum major issues, 6 with the 6.7 and probably 500k with just those Trucks and very high idle time. Lately it seems like an uptick in the failures. Not sure how i feel, dont like the design of the cp4 but still havnt had an issue. My 2022 f350 is at 110k, I’ll probably get another truck later this year. Getting tired of minor issues with fords. Hate ram, migh look into gmc. Since 1997 I haven’t owned anything but ford diesels so lost at features/quality of gm products.
oooh, on edit i just remembered its time to change the filter. Think i got 2k more miles left.
/ CP3 & CP4 pumps
You wouldn’t “hate Ram” after you owned one.
I was a Fordie for life until they screwed us bad on the 6/6.4’s.
Never again.
Had a 2007 Duramax and never should have sold it.
Now I’m in a Ram and with the Cummins and after 4 years, its the best truck I’ve ever owned.
Ram proved to me they were serious about customer satisfaction by replacing the CP4s rather than allowing them to fail while pulling a trailer up or down a mountain.
Afterall, you only get a few pumps on the brakes once the pump takes a dump.
/ CP3 & CP4 pumps #7
Rams junk, Chryslers whole model was to be the harbor freight of the big 3 and now the Italian company said hold my beer. I had a dodge pickup that fell apart.
/ CP3 & CP4 pumps #8
Never again.
Again, ram burnt a few trucks up with the cp4, they were under investigation from the NHTSA when they “voluntarily” did a “recall”.
/ CP3 & CP4 pumps #10
they were gonna have to anyways, the goverment would have made them. Curious how f’n bad you have to make a vehicle that burns up when the pressure pump implodes? Wtf did they do. Gm and ford pumps grenade and no flames.
imagine the engineers that signed off on that fuel system design, what else did they sign off on. We already know ram cant make a front end that doesn't fall apart.
and yea, ford will do everything they can to deny the cp4 warranty. I have no idea about gm. Never owned one. But I've owned dodge….
/ CP3 & CP4 pumps
Maybe they just leak onto a certain spot & get hot or the fuel lines clog & burst. Who knows, but there’s no difference in the pumps -they’re all from Bosch.
Do you know a Ford of GM has never burned?
Still a LOT more responsible to replace all pumps than put a customer through the misery of having a Ford or GM take a dump 2,000 miles from home. That’s got to be a real kick in the shorts staying in some dumpy hotel and flying home while your truck gets towed to the Ford dealer.
Anyway, irrelevant nonsense about Ram aside, I was happy to hear the CP-4 problem doesn’t affect AG tractors and thought it made sense that fuel supply appears to have a lot to do with it.
/ CP3 & CP4 pumps #12
You got me curious and looked up my massey fuel pump, bosch cb18. Deere runs cp4. My kubotas run what looks like kubota pumps. What other ag brands run cp4? Anything with a Cummins?
/ CP3 & CP4 pumps
Hell, BMW runs CP4.
Cummins small trucks for 2 years (resolved)
Lots of AG tractors, but few failures.
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2021 WEILER K560...
2022 PETERBILT 389 (A67714)
2022 PETERBILT 389...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
x (A68191)
x (A68191)
