Covington Cutter
   / Covington Cutter #1
Roadglide3
I purchased A 5' Covington Cutter. The problem is that There is no slip clutch or shear bolt arrangement on the drive shaft. Is this safe? The cutter has a 1 3/8 spline shaft as does the tractor.
   / Covington Cutter #2
I have an old Covington cutter that I junked a few years ago. It also had no gearbox protection. I used it for about 25 years and cut many 2"-3" sapplings and never hurt the cutter or the tractor(s). I'm not saying this is the wise way to go, but just my experience.
   / Covington Cutter #4
Check out CCM- "PTO Shaft Headquaters"
   / Covington Cutter #5
I own a Covington cutter. Was built I think in the 50's. I need to replace the bottom seal, but I can not find any numbers on the seal. Please help.
Bruce
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
iDrive TDS-2010H...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
