correct log splitter valve ?
/ correct log splitter valve ? #1
mike44
At an auction today I bought a 3 pt logsplitter. I do not know anything about them and plan to attatch it to my M-F 165. Somone there told me I needed to know if the control valve on the splitter was "open or closed". Can anyone explain to me what this means, how I determine it and any other advise on hooking it up. The tractor has a plumbed control valve mounted on the fender.
THANKS FOR YOUR HELP!
/ correct log splitter valve ? #2
The term "open" or "closed" refers to the main inlet/outlet ports on the valve. It is usually refered to as "open center" or "closed center". On a open center valve, the fluid flowing into the inlet flows unrestricted to and out the outlet port when the valve is in the center position. When the valve handle is moved away from center, the inlet flow is directed to one of the working ports that would move a cylinder or motor. The system pressure then builds depending upon the load on the cylinder up to the maximum pressure allowed by the safty bypass valves. The other working port is silmultaneously connected to the outlet port on the valve to give the fluid from the other side of the cylinder someplace to go as the cylinder or motor moves. When the valve is moved the opposite direction from center, the inlet flow is directed to the opposite wirking port so the cylinder/motor moves in the opposite direction.
A closed center valve is just that, closed from inlet to outlet in it's center position. Some types of cranes use this type valve in conjunction with a system that maintains a constant high system pressure.
Most tractor systems use open center valves as this places no load on the system(hydraulic fluid is flowing but at very low pressure) untill a lever is moved and some work is being performed then the system pressure varies based upon the work being done. As soon as the work is finished and the lever is returned to center the load is taken off the engine.
It sounds like your tractor already has a control valve on it that controls pressure to a set of ports on the rear of the tractor? You may not need any other valves, the splitter cylinder ports would connect to these ports and you could control the cylinder with the valve on your fender. This however may not be the most efficient for splitting as you have to move to that fender mounted lever to split each log. Most logsplitters have the lever close to the cylinder for convenient ops. It is also safer as the person splitting is the only one who controls the cylinder. In that case, you would need a open center splitter valve(available at northern tool) and connect it's supply and return to those ports on the tractor. You would then use something to hold the fender lever engaged all the time that you are splitting, to supply pressure to the splitter valve. The splitter valve would then be able to control the splitter cylinder.
Simple huh:) If you ae not familliar with hydraulics, this might be a good queston to take to your local hydraulic shop. You will most likley need some type hose/fitting fabricated to get this all working and they will probably be able to give you some advice on how best/safest to accomplish this.
Good luck and post a pic of what you wind up with.
RonMar
Thanks for the information.
I got everything hooked up and splitter works fine. I had to experiment with a couple of selector positions (for the internal pump of the tractor) but all works well. Sure beats the H#@@ out of the maul I was using.
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
