Toplink correc tsize top link
/ correc tsize top link #1
pay1920
Piedmont
Bobcat CT335sst
I just bought a middle buster and the top link that came on my Bobcat CT335 seems too long. The body is 17 1/2 inches long not counting the screw ends when I adjust the top link as short as it will go the plow jus sits on top of the ground,. What size top link do I need and at what angle does the middle buster need to get the most from this tool. Thanks Steve
/ correc tsize top link #2
Even when you try to pull it, dosen't pull itself into the ground?
yes it went in the ground but when I raised it up it flipped over, 180 degrees, like to have never got it back up rite.
/ correc tsize top link #4
Can you post a picture? When I use my middle buster I'd estimate the shaft is leaning back about 15-20 degrees. The further back it leans the deeper it want's to go.
/ correc tsize top link #5
Need pictures.
What flipped over? Did the top link come off?
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
2004 Johnson 40hp 4-Stroke Outboard Boat Motor (A66738)
2004 Johnson 40hp...
CONVEYOR BELT (A68842)
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
2009 TRAIL KING (A67714)
2009 TRAIL KING...
