Toplink correc tsize top link
/ correc tsize top link #1
pay1920
Member
Piedmont
Bobcat CT335sst
I just bought a middle buster and the top link that came on my Bobcat CT335 seems too long. The body is 17 1/2 inches long not counting the screw ends when I adjust the top link as short as it will go the plow jus sits on top of the ground,. What size top link do I need and at what angle does the middle buster need to get the most from this tool. Thanks Steve
/ correc tsize top link #2
Even when you try to pull it, dosen't pull itself into the ground?
yes it went in the ground but when I raised it up it flipped over, 180 degrees, like to have never got it back up rite.
/ correc tsize top link #4
Can you post a picture? When I use my middle buster I'd estimate the shaft is leaning back about 15-20 degrees. The further back it leans the deeper it want's to go.
/ correc tsize top link #5
Need pictures.
What flipped over? Did the top link come off?
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
1982 LOADSTAR LS25LB 96"X30' DOVETAIL TRAILER (A59823)
1982 LOADSTAR...
Mini drum mulcher (A61567)
Mini drum mulcher...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2017 Ford F-350 XL (A60462)
2017 Ford F-350 XL...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
