Core Aerator
/ Core Aerator #1
MIKEKUBOTA
Kubota 2910
Does anyone have an opinion concerning the value and utility of a core aerator? I am looking at either the Land Pride CA25 Series Core Aerators (60 or 72 inch) or the Woods/Gill pl60 or pl72 aerator. I have a B2910 and I would be operating the equipment of a former (flat) cornfield turned lawn.
/ Core Aerator #2
I have one of these: Turfco TM-42 I use it on the lawn Spring and Fall, followed by compost topdressing. I think it is the most important thing you can do for a lawn.
/ Core Aerator #3
They are both good machines, i purchased the woods as it was just a bit heavier than the landpride. Compaction is the enemy of a beautiful lawn, core aeration relieves this and allows water,oxygen and minerals easy access to the root zone.
/ Core Aerator #4
I would prefer the Woods over the LP. Things freeze here in SE Michigan. It's another thing that I do not have to winterize.
I have a First Choice 60". Works good on my lawn.
/ Core Aerator
Thanks for the info. How much weight do you suggest?
/ Core Aerator #6
There is not set rule for weight. Soil quality,depth and moisture all play into the equation. Here in the northeast we deal primarily with bluegrass and strive to pull 3-4 inch plugs. we generally put 700 to 1000 lbs in the weight tray.
/ Core Aerator #7
I have the Woods pl60. well built heavy unit. My buddy had bought a turfco 60 inch right before I bought my Woods and after seeing mine he knew he had made a mistake. He paid the same price for his that I did for mine. Not bashing turfco products but they are not built no where as heavy duty as the Woods. Good luck in your decision!
/ Core Aerator #8
Lawn king... for a lawn with a sprinkler system, do you mark all the heads or do you not worry about them? I have an 1850 and want to plug aerate this spring... should I dethatch first and rake the lawn and then aerate? I too live in the northeast... thanks for any help
/ Core Aerator #9
I've got the same unit as Ronjhall, right down to the same concrete block arrangement.
I've said this before but it bears repeating...weight is not a substitute for moist soil. If you try to put enough weight on an aerator to make it pull 3" plugs from dry ground, you'll probably end up breaking something.
FWIW, I can tell no difference in my grass after aerating for 2 1/2 years. I know it's supposed to be good for it but I can't tell any difference, at least not yet.
/ Core Aerator #10
You will need to mark the heads, if you hit one, it's history. Most systems in the northeast are installed with pipe pulling machines, so pipe depth should not be an issue. It may be wise to inform the client (in writing) that you cant be responsible for pipes that run high, over ledge,etc.
/ Core Aerator #11
CP1969, perhaps it's time for a soil test, have a looksee at whats going on under your lawn.
/ Core Aerator #12
Would anyone be willing to share a price range on the Woods unit?
Also - I have been reading about Leinbach - opinions? I like the idea of
a water-filled core for weight - but I am sure I maybe overlooking the downside?
I "only" have a 2350 so I am concerned about weight on the 3ph...
Curt
/ Core Aerator #13
I have a soil test done every year. I'm not sure how reliable those tests are, though. One year, I was told the ground was acidic and needed lime. I never put any lime on, but the next year the acidity was OK, but potash (I think?) was low. So I brewed up a custom blend of two different fertilizers to put the right amount of potash on without exceeding the Nitrogen application rate.
I'll give it some more time.
/ Core Aerator #14
Curt
Me too, I'd be interested to know a price range for Woods unit like a PL60 or a PL72.
Thanks
/ Core Aerator #15
I purchased my Woods PL60 last year for $1800. plus tax. It listed for over $2000. and they wouldn't take a penny less than the $1800.
/ Core Aerator #17
I have a Midwest 60" that is amazing. No matter how many people have used its, the unit has been viewed as a killer core aerator. Perfect construction and extremely well built.
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
EZ Trail 3400 (A63688)
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
