Cordless Tools vs. Other Options
/ Cordless Tools vs. Other Options #61
Hang on for the new Powerstack.
Yeah, but the pouch batteries are more likely to go up in smoke if you drop them. Not to mention the lower current. But charge cycles are suppose to double. I'll wait and see. There's no reviews yet, just marketing spew. šŸ˜
/ Cordless Tools vs. Other Options #62
I like the 20v Dewalt on drivers and drills, and several tools. The 20v lasts long, maintains power, then drops out when discharged. The 18v is big bulky, heavy, and does not charge as well. They also don't last as long. I was buying them 5 at a time to keep up with my tools. Finally gave them all away for 20v. I can't think of many hand tool which weigh more to haul around than a good 100' extension cord.
/ Cordless Tools vs. Other Options #63
I gave up on battery powered tools and went back to cords. I don't use any one tool enough to keep the batteries alive when I need them.
Why would you not just leave the battery on the charger when not in use? All the talk of dead batteries has me really confused.
  • Good Post
Reactions: LD1
/ Cordless Tools vs. Other Options #64
Some chargers are good with that, some are not. And I don't know which ones (other than DeWalt) do it right.
From the Dewalt web site:
3. DOES IT HURT DEWALT BATTERIES TO LEAVE THEM IN THE CHARGER?
No. The DEWALT chargers have a maintenance mode which allows batteries to remain in the charger, maintaining a fully charged pack until the user is ready to work. If DEWALT NiCd batteries are stored outside of the charger, they will discharge naturally, 15-20% the first 24 hours, 7-10% the next day, and about 1% every day there after. NiCd batteries lose the bulk of the capacity when outside of the charger in the first 3 days. In fact, it is better for the battery to leave it in the charger to be sure it goes through Equalization and Maintenance Modes. One of the benefits of DEWALT XRPā„¢ Lithium Ion batteries is that they have limited self discharge. Storing DEWALT Lithium Ion batteries outside of the charger will not result in loss of charge. Learn more about brushless tools technology.
/ Cordless Tools vs. Other Options #65
Sounds like lawyer-speak ;) I've had lots of different chargers for lots of different tools and batteries and I've never seen or even heard of an actual real world problem. As big as the world is I'm sure somebody has seen one though.
/ Cordless Tools vs. Other Options #66
My local Kubota dealership had a major fire caused by a defective cordless tool battery charger. It was a few years ago and I don't know the brand or whether it was a NiCad or Lithium battery charger. Since then, I use a timer with all my chargers. Every so often I set the timer for a few minutes to top off the batteries even if they haven't been used.
/ Cordless Tools vs. Other Options #67
Not sure if my coments here will add much to the discussion, but like most others, I have given up using Ni-Cad powered gear. However, the frustration is that the tools themselves, though old, are invariably excellent, so I'm attempting to convert them to either Li-ion or if they are 12V adapting them to run with leads off the vehicle battery.
The former is frequently a PITA because rarely do the batteries fit inside without modifying the existing cases. Also because the charging profiles are different, they require either a new motherboard or some form of external charging device and it is critical to use the correct type of charger.
An example is a pair of Einhell cordless drivers - superb quality. I have hard- wired one to work from the car battery, but the other now has 3 X 18650 batteries. A new motherboard is unobtainable and building one is beyond my simple bush brain so the batteries have to be hard wired to the contact plates. To recharge, the battery pack must be removed and connected to a charger. Now comes the tricky bit - which charger?
I've ordered a DC-to-Dc "hobby charger" on Crapbay and if you believe the blurb, the charging profile can be adjusted. It seems the intial charge voltage must be set just slightly above the actual battery voltage for the first phase, then changed to constant current to bring the batteries up to 12.4 volts (or whatever) so they will be fully charged.
If that works, I'll convert a couple of 18V Ni-Cad tools over to Li-Ion.
Please feel free to tell me I'm wrong about any of this, preferably before I burn down the shed
/ Cordless Tools vs. Other Options #68
Interestingly, I've been going retro. I've actually been buying some decent air-powered tools at auction. Nothing can match the compact torque of an air wrench when doing things like big bolts such as for mower spindles, etc. The harbor freight ~25 gallon compressors hold plenty of air for my needs, and the little 1/4" coiled air leads don't significantly impact my ability to get in tight spaces. The air wrench is actually small enough to fit in there much better than a battery drill in most cases. That doesn't mean I still don't use my Milwaukee impact driver for screws and small bolts, but for the big stuff, air works a lot better and faster and is always there. I'm plumbing in Pex air distribution for various places in the garage/barn/shop where I might need to just plug in a tool and do stuff.
Don't rule out air.
/ Cordless Tools vs. Other Options #69
So I have a Dewalt 18V drill and like the flexibility. I don't like however that most of the time I use it both batteries are dead and need a re-charge. I do not do this work for a living and many times find myself just reaching for the corded and grabbing an extension cord. I am wondering if the newer stuff is any different in terms of holding charge or if you are still just always charging stuff all the time like a second job.
I hate the idea of being tied into battery make and therefore tool brand. Has anyone gone a different route and just bought a Jackery (or other) battery generator and still just used your tools? It seems like the batteries on those last a long time from experience. It could also be a dumb
idea. You can get one for the price of a few smaller batteries let alone the 60/80v stuff. Any you can take it camping on the weekend so it isnt' just for tools or use it to keep things going if the power goes out. Seems like it would be more versatile.
Most of the time I work, I'm near a plug so all of this is irrelevant.
Good morning. I've had a 3 piece 18v porter cable set for about 10yrs. It came with the ni-cd type batteries. My charger will due both so l started using lithium from B
Morning. I use Biswaye lithium now for my 18v Porter Cable. Bought it 10yrs back, came with the ni-cd type but since the charger will work with both types l gave them a try. I was surprised with them. $40 each on Amazon. Big box is $60 plus. I just looked at my last Amazon purchase. It was March 2021 and it's still in the box, never charged it yet as my first two l bought are still doing good. I dated them when they were bought. April 2019 & June 2019. Liked the first one then so bought a backup. All l can say is try one. They run along time before needing a recharge. Mine are 4amp. Happy with my choice...
/ Cordless Tools vs. Other Options #70
If I need to drill 1-1/2 holes, I always grab my battery powered drill. Never enough for 2 holes it seems.
/ Cordless Tools vs. Other Options #71
I'm totally spoiled by my Dewalt 20v tools. Still can't believe what I can do with a circular saw, jig saw, pole saw and so on with a battery powered tool.
I bought a Dewalt grease gun (because I'm lazy maybe) and then added others as time moved on over a couple years, and as a result I have probably 5 batteries between two locations (house and lake), and usually another in the trunk of my truck, and with that amount there's literally always one or two ready to go - much easier than managing just one or two batteries.
Thus IMO when you get 3+ tools and 4+ batteries you tend to have a ready one within reach. And if you have a charger or two on your workbench (etc.) in the locations you frequent it's easy just to pop it on there.
/ Cordless Tools vs. Other Options #72
Absolutely! When using one of my work lights, it's full light until it shuts off. The worst is being on a roof and the battery dies. That's another reason I like the new batteries - they have a gauge I can check before I go to one of those really inconvenient situations.
I have had a cordless shaver quit on me while shaving, leaving some whiskers pinched in the cutterhead. Ouch!
/ Cordless Tools vs. Other Options #73
I have had lithium ion batteries still work after being idel for a year. They may slowly discharge, but it is very slowly.
/ Cordless Tools vs. Other Options #74
We exclusively use the Dewalt 20v line and have roughly 25 drills, impacts, saws, routers, sanders and many other miscellaneous tools. Been very happy with just about all the tools.
The drills all came with batteries that are 1.5ah or 2ah which last long enough for drills. The bigger tools we use 4ah or 5ah which last considerably longer. I guess it depends what kind of work youre doing and for how long.
Batteries also don't last forever and you should always keep them fully charged or else they won't last as long whether they're Lion or Nicad. Our 20v batteries have had great life on average though. I just chucked one the other day that was dated 2011.
/ Cordless Tools vs. Other Options #75
I have Dewalt NiCads that are over 10 years old and still work like the day I bought them. Key to NiCads is to run them to dead before recharging. You will avoid the memory effect of NiCads. I also like my Lithium batts in my other cordless tools. Like others say though when they run out they are gone. No slow down. My Milwaukee cordess wrench has a battery charge indicator on it which really saves me. It is my go to tool for working on mechanical things. Best wrench I ever bought.
/ Cordless Tools vs. Other Options #76
I've never had an issue with my robot 40v and Milwaukee 12 and 18 volt. Store them correctly and make sure you give them a full charge before your project. All are lithiums...
My drone lipo batteries will drain 75% after a few days so I always remember to either keep one charged or charge them before I plan to fly.
Plan ahead.
/ Cordless Tools vs. Other Options #77
Cordless is awesome for most applications....however, when I have used bits like an auger bit to drill through cross ties the batteries runs down fast. When I drill something that "bogs" the bit down the battery seems to go quickly. The amount of torque does not seem to have the same effect as I have torqued the heads of lag bolt without seeing a significant loss of battery. I am welcome to any thoughts.
/ Cordless Tools vs. Other Options #79
Unless they are constantly in use, do not keep lithium ion batteries at full chat.
/ Cordless Tools vs. Other Options #80
I bought a drill and driver set of dewalt 20v in 2014. They have been great and I just burned the drill out last week. I have built a house with that drill including drilling all the post and beam joinery with a two foot auger bit. In 2015 I bought a similar set of Makita tools so I could have redundancy in some tools and also liked some of their tool line. I have 5 Makita tools including an angle grinder and reciprocating saw. I have 6 Dewalt tools also. I cant imagine going back to corded drills. Being able to take the grinder and reciprocating saw out on the farm if needed and not have to drag a generator is awesome.
The batteries are stupid expensive.
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
