Copper Air Lines?
/ Copper Air Lines? #21
standard plumbing solder i.e 95/5, silva-brite, bridgit, etc. will take well over a 100 psi. BUT psi is not the only factor, vibration, shock and temp could all play a majior factor. as franz said we use lots of copper in ac&r , running pressures in the 300# pound area and more when a condenser is not up to specs.but the defining factor is the joint medium used and the expertise of the guy doing the soldering.even a water line at min. pressure can make quite a mess when it lets go, so a n air line or refer. line letting go in your face is really not fun.
/ Copper Air Lines? #22
A 100" line of 1/2" copper probably won't bother you blowing up a tire, or even painting with a spray gun, but it's gonna murder your performence with a decent 1/2" impact gun.
The cost consideration between 1/2 and 3/4 copper ain't enough to not use the larger line. If you must use 1/2" for 100 feet, stick a small tank on the end of the line to compensate for air line resistance.
My shop is plumbed with 3'4 black iron, with a second air tank at the far end of the line. I can run a 1" tire gun any place along the line with no loss of performance.
I also have a couple 3/8 copper drop lines running to regulators for painting, soldered with 50/50 solder, and have not had a problem with them. They were installed to insure water could not accumulate in the lines.
I also have 2 water seperators between the compressor and the air system. When I paint something I run a water cooled water seperator ahead of the regulator and gun line.
I akso have a 3/4" black Poly line that runs to the house from the shop system, underground. I keep that line regulated down to 90#, and have never had a problem with it.
Drainage of water trapped in the compressed air is the biggest thing to be considered when Installing a system. If you don't drain an air system you will replace it.
/ Copper Air Lines? #23
Thanks for the good info, Franz. Will come in handy when I plumb air in my shop.
I was going to use SCH40 PVC since it's good to 450psi, and my compressor shuts off @ 140, but I am now thinking about copper. The only problem would be soldering the joints. (I ran into this plumbing my bathroom & heat pump water) The heat from the torch was melting my insulation. This would only be worse with silver solder since more heat would be needed. I suppose I could make some sheilds...
-Ben
/ Copper Air Lines? #24
Only problem I see is way too much unused floor, but don't worry, I can fill it up for you real fast.
The amount of heat required for refridgeration silver solder isn't much more than is required for 50/50 solder. The big tricks are cleaning and the flux. 1/2" drywall with a piece of flashing in front of it will work great for a heat shield, and with a bit of planning you can minimize the joynts you actually have to solder in place. Actually, at 140# of air, 50/50 solder would be more than sufficient for compressed air.
The nice part about a soft solder joynt is that it will seperate itself when water freezes in the line, and mimize the damage.
/ Copper Air Lines?
Nice freakin' shop! Only one problem - getting enough toys to fill it /w3tcompact/icons/wink.gif!
I am jealous.
By the way, thanks to everyone for the great advice.
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
UNUSED RAYTREE RMBD50 - 50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
30 Yard Dumper (A61166)
30 Yard Dumper...
