Coolant
/ Coolant #1
branman1971
Texas
Yanmar YM1700
I am assuming that my model YM 1700 has a water pump cause this picture attached looks to me like a water pump, but I have heard that some models do not and you have to add a specific blend of coolant/water for it to cool properly. Can you guys verify that is what I have and tell me what blend I need to add to the coolant system?
/ Coolant #4
I would install the water pump if you use a brush hog.
/ Coolant #5
...But these things are rated to put out full rated horsepower without fiddling with the cooling.
I would start with getting the radiator rodded out to restore its designed cooling capacity, and only after that see if you need to redesign the tractor.
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
Depth Band wheel, Scapers (A68191)
Depth Band wheel...
11R24.5 Tires - Set of 4 (A68134)
11R24.5 Tires -...
2019 Caterpillar D6N LGP Crawler Tractor Dozer (A66734)
2019 Caterpillar...
