Coolant Temperature Sensor
/ Coolant Temperature Sensor #11
Greg,
I am sorry I was not clearer. What I thought were two wires was wrong. One was a wire only for a small light bulb and the other was not a wire but what appears to be a small copper tube. The reason I pulled the meter was testing with an ohm meter showed no resistance from this "copper tube" to ground. Now I understand why.
A mechanical temperature meter may be very simple but it never worked properly. I am not against replacing my defected temperature gauge with another mechanical temperature gauge but my thinking is I have more thread options with a thermistor sensor and where possible, I want my parts to come from the local auto parts store.
Now if only I could get rid of my "diesel bugs" I would be a happy camper. Yes, I have been using a biocide but it is not controlling/solving the problem. Have decided to switch to a product called Bio Kleen. Have not been able to find locally so will have to purchase from Amazon.
Be aware that if you use domestic gauges from a local parts store you will have to make adapters (see the picture of my temp. gauge in post #6). Domestic gauges are typically 2" OD and will fall through the dashboard otherwise. You can special order 2-5/8" OD domestic gauges but then you will have to enlarge your existing holes. The threaded holes in your thermostat housing are 1/2" NPT metric equivalent.
Wasn't aware you are having bug issues. If you aren't able to control your bugs then you aren't using a true biocide, or your fuel source is badly contaminated and not treated. On the tractor, you must drain and thoroughly clean the fuel tank, clean all screens, change the filter, and refill the tank with known good fuel treated with a real biocide such as Hammond's BioBor JF, and treat subsequent fuelings at least three times. You will have to continually monitor the screen in your sediment bowl for traces. The bugs are highly corrosive to fuel systems and can do some very costly damage.
Biobor Jf Fuel Additives - Products
Bob,
I am aware that hole for the gauge is slightly bigger than 2 3/8" and the domestic gauge is 2". This is an easy fix. Also found out the threads are 3/8" NPT so I purchased another mechanical gauge.
Thanks for the information on the Biobor. The stuff I was using was purchased in a marine store and I do not think it is dual phase. Bio Kleen and Biobor are both dual phase. Will start another thread if the new stuff does not inprove my problem.
/ Coolant Temperature Sensor #13
My diesel experience is limited to small (<3.3 liter) diesels, 5 tractors and 4 autos over 25 years. Never once have I encountered a mechanical temp gauge. Oil gauge, yes. Temp? No. Is there a chance that some previous owner retrofitted an oil temp gauge in place of a coolant temp gauge?
Regarding the biocide, it only kills live organisms. You have to clean out the dead stuff yourself. Boil out the tank and the sediment bowl and the low pressure fuel lines. Might be easier to simply replace bowl and lines with new. Once the fuel path to the filter housing is clean, replace the fuel filter. If you're lucky, the filter caught most of the dead stuff - and the high pressure side may have remained comparatively "bug free".
//greg//
Greg,
Dozer was a crate shipment i.e. brand new. My experience on gas or diesel is zero! OJT, reading on sites like this and helpful people like yourself, Bob, Rich, Tommy, etc. have made all the difference. I knew this would be a learning experience before I even purchased the dozer. Have not regreted the purchase and to all those that share their experience, a special THANKS.
/ Coolant Temperature Sensor #15
Greg,
Every one used mechanical gauges before the advent of electrical gauges.
Capillary tube temp gauges are still very common on diesel powered equipment.
/ Coolant Temperature Sensor #16
Again, my comments are based upon five Chinese tractor engines under 3.0 liters displacement - model years 1999 through 2006. Given the OP forum join date, my comments are submitted on the assumption of a 2004 or newer dozer. That would likely give it the 2.2 liter engine. I never once considered that it might have been delivered with other than an electric gauge.
Minidozer - if you in fact do have a mechanical gauge, look closely around the thermostat housing for a removable plug. That's where a thermistor-type coolant sensor would screw in. Wire that to the ground side of an electric gauge, and connect battery supply to the other side (of the gauge)
//greg//
/ Coolant Temperature Sensor #17
FWIW, my dozer came from the factory new in '06 with a mechanical temp. gauge.
/ Coolant Temperature Sensor #18
I have a similar dozer to Bobs but branded as an East Wind the Bourdon tube (mechanical) temp gauge failed early on and I have replaced with an electric one easy cheap and it works The Bourdon tube type only need a kink or a bruise to the tube to stop working
Mechanical gauges utilize an internal bourdon tube. One end of the bourdon tube is connected to a gear and shaft assembly that moves a pointer. When the pressure inside the bourdon tube increases, the bourdon tube uncoils slightly. The amount of uncoiling that occurs is proportional to the pressure inside the bourdon tube. As the tube uncoils, its motion activates the gear and shaft system that turns the pointer on the gauge. While all that you see when you look at the gauge is the pointer moving, you should understand that there is a small, bent tube (the bourdon tube) that's coiling and uncoiling with each change in the pressure inside that tube.
Mechanical pressure gauges are connected directly to the process fluid being measured (i.e. oil). As the process fluid pressure changes the pressure on the bourdon tube also changes which in turn moves the pointer on the gauge.
Mechanical temperature gauges also utilize a bourdon tube. They have a sealed capillary tube and bulb assembly that is filled with temperature sensitive liquid that produces a proportional vapor pressure on the bourdon tube. As the temperature changes, the pressure inside the bourdon tube changes, which in turn moves the pointer on the gauge.
Replaced temperature gauge with another mechanical gauge, radiator cap (7 psi), thermostst (180 degree) with 3/8" thick rubber doughnut on top and fan belt with HF link belt. Engine temperature came up to ~180 degrees and held. All parts came from local stores.
Coolant System Parts for dozer w/ TY395T 2002.5 engine.
Top Radiator Hose: Goodyear 56024 (5” length, 1 1/2” ID)
Bottom Radiator Hose: Goodyear 52413 (13 3/4” length flex hose, 1 1/2” ID)
Radiator Cap: Stant 18282 (7 psi)
Fan Belt: Harbor Freight link belt
Thermostat: Napa 133, Stant 13548 or MotoRAD 245-180
Note: Need to reduce diameter of flange to fit in engine block and add ~ 3/8” rubber doughnut between top of thermostat and thermostat housing to allow engine to come up to temperature.
Thermostat Housing Seal: FEL-PRO 35063
Note: Needs minor elongation of bolt holes.
Coolant Temperature Gauge: Eguus 6242 (2” mechanical gauge)
Note: OEM temperature gauge hole is 2 3/8”. Equus gauge comes with a mounting bracket that can be modified and screwed to the dash covering this hole. Engine sensor hole is 3/8” NPT. Equus gauge comes with a 3/8” and 1/2” NPT adapter. A ground wire needs to be added for the gauge light to work.
FILTERS
Air - WIX 46210
Fuel - WIX 33972 (5/16” inline 50 micron screen prefilter)
Note: Replaces three hidden OEM screens.
- WIX 33195 (10 micron spin on)
Hydraulic - WIX 51551 (Northern Tool add on)
Oil – WIX 51515
/ Coolant Temperature Sensor #20
Top Radiator Hose: Goodyear 56024 (5 length, 1 1/2 ID)
Bottom Radiator Hose: Goodyear 52413 (13 3/4 length flex hose, 1 1/2 ID)
Note: Need to reduce diameter of flange to fit in engine block and add ~ 3/8 rubber doughnut between top of thermostat and thermostat housing to allow engine to come up to temperature.
Coolant Temperature Gauge: Eguus 6242 (2 mechanical gauge)
Note: OEM temperature gauge hole is 2 3/8? Equus gauge comes with a mounting bracket that can be modified and screwed to the dash covering this hole. Engine sensor hole is 3/8 NPT. Equus gauge comes with a 3/8 and 1/2 NPT adapter. A ground wire needs to be added for the gauge light to work.
FILTERS
Air - WIX 46210
Fuel - WIX 33972 (5/16 inline 50 micron screen prefilter)
Oil WIX 51515
Nice post. Your dozer didn't come with a hydraulic return filter? Wow. Glad you got one on.
2018 John Deere 5075E (A60462)
2018 John Deere...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61307)
2021 Gehl RT215...
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
2016 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2016 INTERNATIONAL...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
