Coolant Ph
/ Coolant Ph #12
</font><font color="blue" class="small">( This is how it is with trucks anyway. If you have ever seen the liners that come out of engines that have had the coolant neglected you would know what i mean )</font>
I have seen it. Pin holes in the liner from the outside inward.
These were on wet sleeved engines (the coolant runs directly around the cylinder liner).
My Kioti tractor does not have wet sleeve type cylinders.
/ Coolant Ph
check out shopdiesel.com they can explain it better than I can.
/ Coolant Ph #14
I do my truck and wife's car every 3 years, @ 30k miles. My previous truck, bought new, was 16 years old with about 150k miles. I never had a problem with the radiator. Distilled water is nice because all the minerals should be gone. I never knew it was a ph of 7.
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2018 Peterbilt 348 T/A Rollback Truck (A59230)
2018 Peterbilt 348...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2019 Ford F-350 (A55973)
2019 Ford F-350...
CAT Chassis Only (A59076)
CAT Chassis Only...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
