Converting Gas engine powered log splitter to tractor hydraulics power
   / Converting Gas engine powered log splitter to tractor hydraulics power #11
Yes, you can get away with a lot of things for a while.
Why not get the right valve for about $75.
   / Converting Gas engine powered log splitter to tractor hydraulics power #12
+1 CJ
   / Converting Gas engine powered log splitter to tractor hydraulics power #13
It will run it no problem but be aware of heat issues. I have seen systems with restrictions [poorly designed] that had heat issues when you turn it into a open system like you are doing. CJ
As I previously stated CCLS is a totally different type hyd system than a true closed center system and many Ford FEL's on CCLS systems had open center valves. I think heat will not be a factor on a CCLS system operating a log splitter with an open center valve.
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2002 LEEBOY L7000T ASPHALT PAVER (A52705)
2002 LEEBOY L7000T...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A55788)
2015 Ford F-250...
2017 Ford F-550 Knapheide Enclosed Service Truck (A55788)
2017 Ford F-550...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
