Converting Gas engine powered log splitter to tractor hydraulics power
   / Converting Gas engine powered log splitter to tractor hydraulics power #11
Yes, you can get away with a lot of things for a while.
Why not get the right valve for about $75.
   / Converting Gas engine powered log splitter to tractor hydraulics power #12
+1 CJ
   / Converting Gas engine powered log splitter to tractor hydraulics power #13
It will run it no problem but be aware of heat issues. I have seen systems with restrictions [poorly designed] that had heat issues when you turn it into a open system like you are doing. CJ
As I previously stated CCLS is a totally different type hyd system than a true closed center system and many Ford FEL's on CCLS systems had open center valves. I think heat will not be a factor on a CCLS system operating a log splitter with an open center valve.
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
ASSET DESCRIPTIONS & CONDITION (A54607)
ASSET DESCRIPTIONS...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
