Converting Gas engine powered log splitter to tractor hydraulics power
   / Converting Gas engine powered log splitter to tractor hydraulics power #11
Yes, you can get away with a lot of things for a while.
Why not get the right valve for about $75.
   / Converting Gas engine powered log splitter to tractor hydraulics power #12
+1 CJ
   / Converting Gas engine powered log splitter to tractor hydraulics power #13
It will run it no problem but be aware of heat issues. I have seen systems with restrictions [poorly designed] that had heat issues when you turn it into a open system like you are doing. CJ
As I previously stated CCLS is a totally different type hyd system than a true closed center system and many Ford FEL's on CCLS systems had open center valves. I think heat will not be a factor on a CCLS system operating a log splitter with an open center valve.
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A55787)
2015 Vermeer SC362...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
Mobile toilet with shower (A53424)
Mobile toilet with...
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
