Converting Gas engine powered log splitter to tractor hydraulics power
   / Converting Gas engine powered log splitter to tractor hydraulics power #11
Yes, you can get away with a lot of things for a while.
Why not get the right valve for about $75.
   / Converting Gas engine powered log splitter to tractor hydraulics power #12
+1 CJ
   / Converting Gas engine powered log splitter to tractor hydraulics power #13
It will run it no problem but be aware of heat issues. I have seen systems with restrictions [poorly designed] that had heat issues when you turn it into a open system like you are doing. CJ
As I previously stated CCLS is a totally different type hyd system than a true closed center system and many Ford FEL's on CCLS systems had open center valves. I think heat will not be a factor on a CCLS system operating a log splitter with an open center valve.
Advance SC750 28in Floor Scrubber (A55787)
Advance SC750 28in...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
New JMR 40" Skidloader Grapple (A50775)
New JMR 40"...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A55787)
2025 GIYI GY-BK56M...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A54607)
2018 HINO 268 NON...
2011 FORD F-450 (A52472)
2011 FORD F-450...
