Converting a woodsplitter into a firewood processor
   / Converting a woodsplitter into a firewood processor #61
I was wondering about putting a 2 cylinder setup on my build but couldn't find out if that would actually double the pushing power. I have a couple 4", 30" long cylinders I came across. Been looking for a 5 inch one but haven't been able to find one yet......cheap that is.:D
finding matching cylinders at a scrap yard is a crap shoot. I looked for quite a long time without any luck. To big, to small, to long to short. A member on the arboristsite sent this link craigslist | Page Not Found and I bought 8 of those cylinders. I didnt want but 2, but truck freight made shipping cost more than the cost of the cyl. I bought all he had left so i could spread the cost of the freight. I'll probably sell what I dont need locally, unless someone wants to drive to pick one up. I have 5 for sale, but the freight on 1 makes shipping out of the question unless someone is desperate. 4.5bore, 29.5in stroke, 2.5in rod. Base pins are 2.5in dia, rod pins, 2in dia. Ports 1in. These cylinders are new surplus W24 Case loader cylinders. They are over $5700 each new. With The freight I had to pay to get them, I need $200 each to come out, but thats still a deal considering USA made versus the China made cyl at Northern or TSC
Using two cylinders of the same bore will double your force, not exact, but close enough. 2-4in cylinders will be about the same as 1-6in cylinder.
Whoops, link no longer works, but was working when I started this post. I have pics if anyone is interested.
   / Converting a woodsplitter into a firewood processor #62
I wonder what that does to the cycle speed? I have two good cylinders that are basically the same that I could use. The ones you have would be worth doing a road trip for if I didn't already have these two.
I had been thinking about trying to go that route but I couldn't find any information as to just what it would do. I have seen pictures of splitters and processors using two cylinders but nothing was written about what they produced in splitting power nor were they willing to talk about it. Manufacturers can be really tight lipped at times and if you don't have access to engineering specs or been to engineering school and can figure all this mess out on your own it gets into the hit or miss category in a hurry. It takes a lot of time, work, and iron, laying out and fabricating all the brackets and other stuff that makes something like that work properly to not end up with something that produces more splitting power.
I was also wondering how to plumb a setup like that without one cylinder taking more of a hit than the other. I guess a 'T' between the two cylinders and a larger feed line back to the valve would work. But, that's the kind of stuff you have to find out before you go spending a lot of time and money putting something like that together. I'm getting too old and broke to keep doing things the trial and error way like
i have been doing.:laughing:
   / Converting a woodsplitter into a firewood processor #64
If they are the same size and the flow is the same, the cycle speed would be half the speed of a single cylinder.
In real life with a 2 stage pump, the pump should spend less time in the high pressure stage and more in the high flow stage (twice as much surface area to push against, so twice as much pressure on the push plate for the same hydrualic pressure).
If you tee both the inlets and the outlets and feed the tees with a larger hose, they should flow the same.
If the cylinders have 1/2" ports and you want to keep the hose velocity under 15FPM, you would need to feed the tee with a 3/4" hose (to feed 18GPM vs 9 GPM per the chart found on page 3 of this Parker hose sizing guide.
Aaron Z
   / Converting a woodsplitter into a firewood processor #65
twice as many cylnders with same oil flow will cut the speed in half, but will double the force. Assuming both cylinders are the same size. As for splitting the flow between two cylinders, you can spend all kinds of money buying divider or proportioning valves, but for a wood splitter where both cylinders are mounted side by side or stacked, the easiest method would to just use a oversize tee. Use the biggest size hose you can from your control valve and use matching size hoses from tee to cylinder. The tee acts like a manifold distributing the fluid evenly between the cylinders. Now if the cylinders you wish to operate at the same time where spaced out, such as with a FEL lift cylinders, then you would want to use a divider or proportioning to keep the cylinders working evenly. With stacked cylinders mounted inches apart and attached to the same push/mounting plate, I would just use the tee, Which is what I plan on doing.
   / Converting a woodsplitter into a firewood processor #66
I should mention, we have engineering at my company... maybe we could help in that aspect...
   / Converting a woodsplitter into a firewood processor #67
You could run that setup with one guy. Load log deck, cut till empty. Repeat.
That video is showing "family wood time". Having two little kids who "want to help" Im real familiar with the concept... Basically a lot of people running around trying to help but doing nothing;)
Regarding this processor in the viddy http://www.youtube.com/watch?v=33t4V1Wyp6c#t=272
One thing I like about that idea, is the idea of "containerization" of the wood in the trailer. You load those baskets, get home and move them with tractor under shelter, bring into garage with tractor one at a time, or back deck, or what have you.... but you don't handle and stack the wood 18 times. Typical german engineering, they decided not to handle the wood with brawn, and so they don't - at all!
My old man, decided he didn't like the looks of the wood pile or woodshed here at our compound, so it's a quarter mile away on our property, where you can cut the wood and leave the waste laying and and that..... but stacking it in his "manger" , then hauling it from there to the house, which when he's around is: stacking it in the tractor bucket, then driving to house, restacking it in garage in wood rack....... Built the manger with scrap wood and it's not tall enough to stand in, so I can't carry wood in and out without hitting my dang head!
Does anyone else but me get weary of this never ending re-handling of firewood?
It's got to be done, I'm just always wondering "there's got to be a better way" so that you're not rehandling it so much. And I forgot to mention, for those of us with no firewood processor, cutting it, bucking it, throwing it in the trailer, then handling it to split it, then picking it up to get it stacked, etc etc... You all know this too well....
I just wonder if a proper system should also include that kind of thing so that you don't need to haul it.
I'm fresh back in the upper midwest after being in sunny California for a decade and a half, and so I'm reacquainting myself with wood handling and burning. Curious what you guys are doing....
Perhaps a design for a wood "pod" that holds a whole face cord. 2 rows, 4 x 4 x 16" so the unit size is roughly 4 x 4 x 3 ft. Built in fork tubes, and a caster cart at home so you can drop it with loader at the garage door, and then push it into that nook by the door into the garage (that's how we are set up...)
I like the idea of the conveyor just piling it into the basket, but then you're having to lean over the basket all the time to get the wood at the bottom. Removable side would be OK, but might just spill out. Maybe there's a minimum amount of cross tubes that would work well enough and you could remove them one at a time, or reach thru for the wood.
Yeah, the investment on building your baskets wouldn't be cheap, but you'd get all of your handling done in the warmer weather. If I bring it with tractor, I have to start tractor, warm it up 10 minutes, load in bucket (just a 5 foot little bucket) unload in garage, then get another bucket.... I've ended up just getting a load on the tailgate of my truck once a day instead of doing it smarter somehow.
Does anyone handle their wood smart?
   / Converting a woodsplitter into a firewood processor #68
Regarding this processor in the viddy Brennholz machen mit S
I use firewood bags. They cost $3.50 each and I've been able to reuse most of them at least once. I welded up a frame that sits over a pallet and hold the bag open. My processor (I'm building it now) will dump wood into the bags. My tractor then carries them away and you can stack them 2 high. When I need more firewood, I grab a pallet, but it on a dolly I build, put it on the back deck and roll it to the back wall. Each bag holds one face cord. You need a pretty strong tractor to lift a face cord, they're over 2000# with green hardwood and they stick out 4' in front of the loader.
Right now, I stack in rows, but in the future when I have a larger tractor, I plan on going with bags.
You really need 2000# + lift capacity to handle wet wood in any efficient quantity. Yes you can stack small pallets to keep the weight down, but that sort of defeats the purpose.
There are several other options other than the big bulk bags. As you said, most of these "advanced" firewood handling ideas come out of europe.
One that looks promising and may be cheaper than bags is to use net wrap. The device isnt that complicated. Notice how the euros dry their wood in long splits (1m+) which makes for easier stacking then use a dedicated saw to recut into stove length. Of course you could skip the long drying splits and just go with the netwrap and stove length splits. Member 94Bullitt on here has tried using netwrap with some success.
   / Converting a woodsplitter into a firewood processor #70
So what do you do with the netting after? The bags I can see being reused but if the netting is garbage after, it's rather wasteful.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Sedan (A59231)
Sedan (A59231)
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
