Converting 2wd to 4wd
/ Converting 2wd to 4wd #21
You can get by with a loader on a 2wd, even power steering is not really necessary. The trouble is, once you use one with these features it is very difficult to give them up because they improve performance by such huge margin. As long as you don't know what your missing then everything will be fine.
/ Converting 2wd to 4wd #22
I used a friend's old Kubota without PS (and a small loader) for a few hours.
Yeah, you can do it...you'll have arms like Popeye in a few months! Maybe that's not a bad thing...
/ Converting 2wd to 4wd #23
Just think of it as good cardio workout and upper body. That's what i tell myself when i use my 2 1955 vintage tractors with loaders.... no canopy.. You plenty of the 'sunshine vitamin that way!!
Soundguy
/ Converting 2wd to 4wd #24
RoyJackson said:
You could add the FEL knowing this would not be optimal. Power steering would be of more value then 4WD, IMO. If your tractor doesn't have power steering, I don't think you should add the loader.
For small occasional jobs, I think you could get by without 4WD (or MFWD). Just because my 790 has 4WD doesn't mean I use it for every job (most though). There will be jobs requiring extra work due to the lack of 4WD...just depends if you can live with that.
Once you price out the FEL and hydraulics, you may decide to trade though.
Roy .. I'm gonna have to disagree here. While there will definitely be some usage of the FEL with 2WD, I think the real issue is a safety issue.
Being both pulled and pushed simultaneously with a heavy load in the bucket goes a long way to stabilize. Those are impressive load's on Chris's Fords, but they wouldn't make for warm fuzzies if the ground was uneven or rutted ... (as in not flat) ..
/ Converting 2wd to 4wd #25
That's cool...we all disagree at some time.
But...my opinion...it would be safe enough with a modicum of common sense.
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
Kubota BX2200 (A64911)
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
CAT R550/D11R Ripper Teeth (8) (A68134)
CAT R550/D11R...
2021 Bobcat T66 Compact Track Loader Skid Steer (A66734)
2021 Bobcat T66...
