Convert to Live PTO
/ Convert to Live PTO #1
Gary Mickle
Lakeville, Ohio
MF 135
I have a 1956 Ferguson TO 35 that I really like a ;lot. Only thing is I wish it had a live PTO. Is there anyway to convert it to a live PTO? Thanks - Gary
/ Convert to Live PTO #3
Easy way? I don't think so.
The 1958-60 TO-35 Deluxe has the 2-stage clutch (live pto).
So, I'd look for one of those later models.
/ Convert to Live PTO #4
I have a 1956 Ferguson TO 35 that I really like a ;lot. Only thing is I wish it had a live PTO. Is there anyway to convert it to a live PTO without a big expense? Thanks - Gary
easy way? not really..
non expensive way? not really
possible? kinda
your gergy has a single stage clutch.. etc.. stomp on the foot clutch and drivetrain and pto stop.. pto is off the countershaft.. thus stopping the input shaft stops cpto and pinion.
there is a rear pinion clutch that fit the ford N and later the ford NAA.. the later one was hyd applied using a small pump off the nose of the tach drive on the hyd pump.. line ran back to a side cover to a control valve.. that valve controlled a hyd clutch pack that was installed in place of the hollow coupling tube that ran from the aft of the tranny to the pinion ( and ring gear ).
throwing theat lever clutched the pinion.. thus tractor stopped moving.. but if you didn't stomp the clutch.. pto stayed running.. thus you added a 2nd stage to your clutcvh.. down the line. some other tractors had a similar setup.. foot and hand clutch to accomplish similar.
there was a straight mechanical version for the 8n.. those were both commercially produced. i have seen a third one that was made at a machine shop, way back in the 50's.
I have also see a guy build an AXLE clutch that used the open diffy to accomplish the same thing.. though MUCH MUCH more difficult to implement.
i'd think a simple mechanical pinion cluitch would be the way to go.
it's very possible the unit from a ford 8n may be a mor eor less drop in / custom fit in that very similar early fergy. on the other hand.. the 'starting parts' for this project would be one of them pinion clutch kits.. and I have seen them go for 800-1000$.. and then that would just be the operational basis that then you might have to weld/grind/machine/fabricate on a bit to make work.
alternately.. you could scratch fab a kit using similar setup.. make a clutchable connection out of the area wher ethe hollow pinion tube now sets... plenty of room in there above the pto shaft.. pretty much just needs a hyd clutch, and then a small volume engine driven pump on the engine.. like a power steering pump... etc.. that.. or just go mechanical...
/ Convert to Live PTO #5
easiest way buy a to/mf 35 delux
easier way buy a to/MF 35 or early 135 swap your front end including engine onto the live pto trans rear end
or you can buy my MF 35 deluxe :)
/ Convert to Live PTO #6
for sure easier to simply buy a machine with live pto.. sell olfder one for 75-90% of the cost and be WAY ahwead and not reinventing the wheel... for sure!
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
(20) 5M HIGH END RATCHET STRAPS (A64280)
(20) 5M HIGH END...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
UNUSED WOLVERINE QUICK COUPLER 10 (A64281)
UNUSED WOLVERINE...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
John Deere 6130M (A64126)
John Deere 6130M...
