Convert Continental Post Hole Auger to a logging winch
   / Convert Continental Post Hole Auger to a logging winch #1
pjf
Just as the title says. Is it possible. I have a continental post hole auger sitting around collecting dirt. Would it be possible to convert to a skidding (logging) winch
Thanks
With some minor fab work, I was thinking of replacing the auger bit with a pto shaft and putting a pto winch half way down where the auger would go. Opinions or other suggestions
Thanks
   / Convert Continental Post Hole Auger to a logging winch #4
You will probably want your winch to be reversible, too.
Bruce
   / Convert Continental Post Hole Auger to a logging winch #5
I suspect you would also have to add some form of clutch and brake system and also free wheel option to the auger drive to make it a winch. Is this PTO powered auger or hydraulic? If hydraulic the reverse should be there already.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
