Convert Continental Post Hole Auger to a logging winch
   / Convert Continental Post Hole Auger to a logging winch #1
pjf
Just as the title says. Is it possible. I have a continental post hole auger sitting around collecting dirt. Would it be possible to convert to a skidding (logging) winch
With some minor fab work, I was thinking of replacing the auger bit with a pto shaft and putting a pto winch half way down where the auger would go. Opinions or other suggestions
   / Convert Continental Post Hole Auger to a logging winch #4
You will probably want your winch to be reversible, too.
Bruce
   / Convert Continental Post Hole Auger to a logging winch #5
I suspect you would also have to add some form of clutch and brake system and also free wheel option to the auger drive to make it a winch. Is this PTO powered auger or hydraulic? If hydraulic the reverse should be there already.
24220 (A56859)
24220 (A56859)
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
Loader Bucket (A59228)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
48in Ditch Witch Harley Rake Mini Skid (A56436)
48in Ditch Witch...
ADS Bulk Seed Buggy (A59814)
ADS Bulk Seed...
