bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,535
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
While I agree with you, I have found that in some cases 2 seem to work better for whatever reason??They are cheap and it does not hurt to use 2 and then your covered.
Just a followup for those interested. I installed a single .031 restrictor fitting on the Landpride plow. The plow swing speed was too slow so I drilled it out to .043 (#58 drill bit). The speed is acceptable but a .045 fitting would be better. I noticed a loud bang when closing the 3rd function valve while swinging the plow in one direction but not the other. I installed a second restrictor fitting and the noise went away. I'm not sure using a single fitting would have done any harm but using 2 is cheap insurance. The function is the same either way.
Thanks for your advice Brian.
