Snow Controlling Angle Speed on a FEL Plow
   / Controlling Angle Speed on a FEL Plow
While I agree with you, I have found that in some cases 2 seem to work better for whatever reason?? :confused: They are cheap and it does not hurt to use 2 and then your covered. ;)
Just a followup for those interested. I installed a single .031 restrictor fitting on the Landpride plow. The plow swing speed was too slow so I drilled it out to .043 (#58 drill bit). The speed is acceptable but a .045 fitting would be better. I noticed a loud bang when closing the 3rd function valve while swinging the plow in one direction but not the other. I installed a second restrictor fitting and the noise went away. I'm not sure using a single fitting would have done any harm but using 2 is cheap insurance. The function is the same either way.
Thanks for your advice Brian.
   / Controlling Angle Speed on a FEL Plow #12
Thank you for the feed back. This can help out many people as well as I now know to recommend .045 for this attachment. :thumbsup:
   / Controlling Angle Speed on a FEL Plow #13
Thanks for posting back your end result and glad to hear you found an acceptable solution.
   / Controlling Angle Speed on a FEL Plow #14
I think it already was mentioned but... I'd make sure you installed the restrictors fittings upstream of the crossover relief valve. You want that valve to let the blade angle quickly (unrestricted) if necessary.
The restrictors on my TnT lug the engine a bit & cause some slight squeeling (not just the relief valve). But it makes it so much more controlable & usable. By far worth it.
   / Controlling Angle Speed on a FEL Plow #15
You know that if you feather the valve just a bit, the unit will still move at basically the same speed and you won't have the squealing or engine lugging. Or are you talking about your 3rd function, then it is what it is.
   / Controlling Angle Speed on a FEL Plow #16
Ya, but the OEM Kubota valves & especially linkages suck. Very hard to feather & often stick. Moving the lever for 1 valve will often actuate the other. I'd have fiddled with it myself already, but I knew I'd be taking it in for warranty work.
I need to add restrictors to my SSQA plow here at some point. No flow control on my 3rd function on the loader so it will be an issue.
Finally taking it in for those & leakdown issues with the rear valves here this week.
I have the same leak down and sticking problems with the 3 remotes on my L6060. Using a known good cylinder, I verified the leak down is definitely a valve issue. The sticking problem is due to the convoluted linkage system used to get the levers in a nice neat location in the fender console. When I mentioned these problems to the dealer, I was told it is a known issue with no fix at present. I hope you have better luck and please post your results.
   / Controlling Angle Speed on a FEL Plow #18
Actually dropped it off today. We'll see how it goes & what they come up with. I have decent faith in my dealer, less so in the Kubota valves. Dealer mentioned lockout valves, but I'm not interested, I like float to much.
   / Controlling Angle Speed on a FEL Plow #19
A band aid for poor quality IMO. :( I sure hope your dealer comes through for you.
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
SUV (A59231)
SUV (A59231)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
