Control valve kit.
/ Control valve kit. #1
arboristjames
Port Angeles, Wa..
JD 650,Horse1 tiller
Hi, I have a 2 spool valve that I am looking for a detente kit for 1 of the spools. I have seen these valves listed on Amazon and Northern Tool, their description is "Universal 2 spool, 25 GPM with 1 1/4" inlet and 1 " outlet, double acting 3000#. I have contacted 2 of the distributors of these valves neither of which sold the kits or very helpful either as well as at least a dozen "specialists". If anyone here has, or know where I can get one, I would be extremely grateful. Thank you for any help you can offer, James.
/ Control valve kit. #2
If I am correct your tractor is from the 1980's. Further that the 2 spool valve is of the same vintage
Getting a kit that is made for such an old valve is not possible.
Having a 25 gpm valve on a low hydraulic flow tractor is a bad idea. You end up with a valve which cannot be finely controlled and further, you also end up with far too big hoses making installation difficult and costly.
How about telling us why you want a detent and the type of detent as there are different types.
Dave M7040
/ Control valve kit. #3
I'm with Dave M7040, to big of a valve for a little tractor. That could of not been JD's doing. Save that valve for something else and buy another one at 8 to 10 gpm with what you want in the valve.
Sorry, I screwed up. I did not explain that this question is NOT related to my little tractor, this is about piece of equipment that I am building. It is directed at anyone with knowledge of the valve and where I might be able to buy the detente kit for it. I thank you for responding and again apologize for wasting anybody's time James
/ Control valve kit. #6
Who is the actual manufacturer of the valve?
BTW...As a last resort you should be able to use the "universal" detent...it's called a "bungee cord"...:D
/ Control valve kit. #7
You might have to get a new valve that has the detent already...
Maybe you never noticed but bungee cords only work one way!
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
