Control valve kit.
/ Control valve kit. #1
arboristjames
Port Angeles, Wa..
JD 650,Horse1 tiller
Hi, I have a 2 spool valve that I am looking for a detente kit for 1 of the spools. I have seen these valves listed on Amazon and Northern Tool, their description is "Universal 2 spool, 25 GPM with 1 1/4" inlet and 1 " outlet, double acting 3000#. I have contacted 2 of the distributors of these valves neither of which sold the kits or very helpful either as well as at least a dozen "specialists". If anyone here has, or know where I can get one, I would be extremely grateful. Thank you for any help you can offer, James.
/ Control valve kit. #2
If I am correct your tractor is from the 1980's. Further that the 2 spool valve is of the same vintage
Getting a kit that is made for such an old valve is not possible.
Having a 25 gpm valve on a low hydraulic flow tractor is a bad idea. You end up with a valve which cannot be finely controlled and further, you also end up with far too big hoses making installation difficult and costly.
How about telling us why you want a detent and the type of detent as there are different types.
Dave M7040
/ Control valve kit. #3
I'm with Dave M7040, to big of a valve for a little tractor. That could of not been JD's doing. Save that valve for something else and buy another one at 8 to 10 gpm with what you want in the valve.
Sorry, I screwed up. I did not explain that this question is NOT related to my little tractor, this is about piece of equipment that I am building. It is directed at anyone with knowledge of the valve and where I might be able to buy the detente kit for it. I thank you for responding and again apologize for wasting anybody's time James
/ Control valve kit. #6
Who is the actual manufacturer of the valve?
BTW...As a last resort you should be able to use the "universal" detent...it's called a "bungee cord"...:D
/ Control valve kit. #7
You might have to get a new valve that has the detent already...
Maybe you never noticed but bungee cords only work one way!
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2025 Bobcat T650 (A64126)
2025 Bobcat T650...
159120 (A60430)
159120 (A60430)
