Control valve kit.
/ Control valve kit. #1
arboristjames
Port Angeles, Wa..
JD 650,Horse1 tiller
Hi, I have a 2 spool valve that I am looking for a detente kit for 1 of the spools. I have seen these valves listed on Amazon and Northern Tool, their description is "Universal 2 spool, 25 GPM with 1 1/4" inlet and 1 " outlet, double acting 3000#. I have contacted 2 of the distributors of these valves neither of which sold the kits or very helpful either as well as at least a dozen "specialists". If anyone here has, or know where I can get one, I would be extremely grateful. Thank you for any help you can offer, James.
/ Control valve kit. #2
If I am correct your tractor is from the 1980's. Further that the 2 spool valve is of the same vintage
Getting a kit that is made for such an old valve is not possible.
Having a 25 gpm valve on a low hydraulic flow tractor is a bad idea. You end up with a valve which cannot be finely controlled and further, you also end up with far too big hoses making installation difficult and costly.
How about telling us why you want a detent and the type of detent as there are different types.
Dave M7040
/ Control valve kit. #3
I'm with Dave M7040, to big of a valve for a little tractor. That could of not been JD's doing. Save that valve for something else and buy another one at 8 to 10 gpm with what you want in the valve.
Sorry, I screwed up. I did not explain that this question is NOT related to my little tractor, this is about piece of equipment that I am building. It is directed at anyone with knowledge of the valve and where I might be able to buy the detente kit for it. I thank you for responding and again apologize for wasting anybody's time James
/ Control valve kit. #6
Who is the actual manufacturer of the valve?
BTW...As a last resort you should be able to use the "universal" detent...it's called a "bungee cord"...:D
/ Control valve kit. #7
You might have to get a new valve that has the detent already...
Maybe you never noticed but bungee cords only work one way!
UNUSED GIYI CW59-59" COMPACTION WHEEL (A62130)
UNUSED GIYI...
2019 VANGUARD REM VXP 53X102 T/A DRY VAN TRAILER (A59909)
2019 VANGUARD REM...
1929 PACKARD 4 DOOR SEDAN (A59909)
1929 PACKARD 4...
429646 (A61165)
429646 (A61165)
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
(1) UNUSED 18X9.50-8 TIRE ONLY (A62130)
(1) UNUSED...
