Considering pruchasing a IHI 35J. Cold start problem?
/ Considering pruchasing a IHI 35J. Cold start problem? #1
XxLT250RxX
Bronze Member
NW Alabama
IHI 35J needs a shot of either each morning to start. Starts fine the rest of the day. Runs like a sewing machine.
/ Considering pruchasing a IHI 35J. Cold start problem? #2
Check the compression first. It should have 440 psi. I just rebuilt one.
What involved in doing a compression test? I done it on gas engines but never diesel. Does the engine in the IHI have sleeves? It sound like parts for the IHI is not very common.
/ Considering pruchasing a IHI 35J. Cold start problem? #4
I pulled the glow plugs. You’ll need a diesel compression gauge kit. Which will have the correct threads. I brought one for Harbor freight for cheap. Three cylinders don’t have sleeves but four cylinders do. Ihi is a good machine new name is Kato
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
(2) 15 Gallon Sprayers, 25 Gallon Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gallon...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2004 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2004 Ford F-250...
