considering a stump puller
/ considering a stump puller #1
aerojunkie
Kannapolis, NC
Mahindra 2538
/ considering a stump puller #2
LOTS of threads on here. Search for 'tree puller' or 'tree and post puller'.
/ considering a stump puller #3
For a tractor I recommend a puller that will also fit on the more powerful three point hitch: Buckthorn Puller - Custom built Skid Steer attachments to fit almost any need you may have.
From LouieJunior: http://www.tractorbynet.com/forums/attachments/318149-tree-puller-pleased-my-new.html#post3845905
/ considering a stump puller #4
I use a puller like the one you pictured often. 4" pine would be ok. 4" with a good root system is going to be a bit of work for your 2538.
/ considering a stump puller #5
I am thinking of buying a stump puller like the one below. The question is most of the videos I see they are on skid steers with a lot more lift, so would they be worth anything on a tractor with around 1600lbs lift capacity? Looking to pull stuff 4" or less in diameter.
Tree Fence Post Puller Skid Steer Attachment Quick Tach Bobcat Kubota Case
I have one and use it all the time on my 2540. Worth it, even with the lift capacity of the smaller tractors. Lift and push and pull, and most things will pop right out. I've pulled dozens of 4x4's that were cemented in.
/ considering a stump puller #6
call me cheap.....lighter and can use with the 3Pt for more umph...
But is more labor intensive
For Sale L4479 Snowblower and Subframe
For Sale L4479...
7888SFL (A61567)
7888SFL (A61567)
2015 LeeBoy 8510C Asphalt Paver (A61572)
2015 LeeBoy 8510C...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
Kubota L175 Tractor (A62613)
Kubota L175...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
