Backhoe Confusion about 3rd function
/ Confusion about 3rd function #21
Not to get off topic, but I would use caution with the placement of your hooks. Looks like they're mounted a good bit outside the arms. Careful not to twist your loader.
As to the OP. I used this setup for my 4025.
Construction Attachments Dedicated Third Function Hydraulic Valve Kit, Less Hoses, Up To 14 GPM Had my local hose shop fab what I needed and saved a couple of hundred dollars.
Thanks for the comment about the hooks, I am about to install mine and didn't know if there was a right or wrong way to do it.
Sounds like i need to line them up with the loader arms or inside a bit, does that work well?
/ Confusion about 3rd function #22
Yep, that's the place. There's a thread on it. Do a search for "bucket hooks".
/ Confusion about 3rd function #24
Thanks tkevan!
I'll search for it.
Or you can do what my dealer did and put one in the middle. I've never found a need for more than on and with both arms splitting the load there is little danger of twisting the loader.
1980 FRUEHAUF 45' T/A FLATBED TRAILER (A59911)
1980 FRUEHAUF 45'...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
2021 John Deere S790 Combine (A63111)
2021 John Deere...
2008 Ford F-350 Pickup Truck (A61573)
2008 Ford F-350...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
