Backhoe Confusion about 3rd function
/ Confusion about 3rd function #21
Not to get off topic, but I would use caution with the placement of your hooks. Looks like they're mounted a good bit outside the arms. Careful not to twist your loader.
As to the OP. I used this setup for my 4025.
Construction Attachments Dedicated Third Function Hydraulic Valve Kit, Less Hoses, Up To 14 GPM Had my local hose shop fab what I needed and saved a couple of hundred dollars.
Thanks for the comment about the hooks, I am about to install mine and didn't know if there was a right or wrong way to do it.
Sounds like i need to line them up with the loader arms or inside a bit, does that work well?
/ Confusion about 3rd function #22
Yep, that's the place. There's a thread on it. Do a search for "bucket hooks".
/ Confusion about 3rd function #24
Thanks tkevan!
I'll search for it.
Or you can do what my dealer did and put one in the middle. I've never found a need for more than on and with both arms splitting the load there is little danger of twisting the loader.
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
17398SFL (A61569)
17398SFL (A61569)
LandHonor LHR-SL2T3M 2-Ton Chain Hoist (A60352)
LandHonor...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
