Confirm I'm doing it right. Adding 3 spool for remotes
   / Confirm I'm doing it right. Adding 3 spool for remotes #11
So as I see it the only way I could really do this would be to cut that hard line, then connect a line to it go to the new valve, then out that valve and connect to the other half of the hard line.
I have made my own brake lines and then headed to the racetrack but I'd hesitate to cut a 3000 psi hydraulic line and assemble an end on it. You can get hydraulic rated adaptors for just about any fitting. If I were doing it I'd buy lines and use adaptors to match the fittings on the loader valve and stock remote.
   / Confirm I'm doing it right. Adding 3 spool for remotes #12
Everhard, I'm not a hydraulic guru but why don't you simply replace that hard line with a flex hose line? Then you could couple up the valves as you desire. That is how my 3 spool valve was put in place and works just fine. Greg
Ericm979 - Agreed, my thought was to take it to a hydraulic shop to make the ends, doing that myself would be out of my scope.
Gregster613 - My thought is depending on how much Kioti wants for that hard line I'd get one to cut and have ends put on. The space at the loader valve is tight and I don't know if I'd get a connector on there. Possibly. In any event right now I can't have the tractor down for any length of time at all because winter is right around the corner. But I do want to get that valve operational so that I can change the chute on my blower from manual rotation to hydraulic. I think I'll look at doing as you suggest. Also keep in mind in addition to replacing that hardline I'll also have to T into a return line as well.
I'm glad I did ask the initial question and the responses I got from all of you - I've learnt more, and ultimately it'll allow me to set this up better!
Thanks all!
E.
   / Confirm I'm doing it right. Adding 3 spool for remotes #14
Just curious, have your current single valve connected to a cylinder , pull the control lever all the way actuating the cylinder and at the same time raise the 3pt hitch.
What happens? Depending on how things are plumbed, there is a chance that the hitch will not raise. If the hitch does not raise, then what you want to do to get by is not going to workout very well for you.
Please report back.
Mtnviewranch - I do that all the time, when my rear remotes are hooked up to the top link, when I adjust the top link the remotes take priority over the 3pth assuming I'd made an adjustment to the 3pth right before that. (For example I've a set of forks I use on the rear a lot)
So I see what you mean, to adjust the 3pth I'd have to first knock the stock rear remote lever back to center before using raising/lowering the 3pth.
I'm assuming even if none of the valves on the new 3 spool are being used just because the stock rear valve is activated it'll not allow the 3pth to move. Actually I've the backhoe hooked on at the moment so I can test it that way.
I'm at work so that test will happen tomorrow, thanks!
E.
   / Confirm I'm doing it right. Adding 3 spool for remotes #16
E.
Correct, if your stock valve is open, the 3pt will not raise, or that is how it is on most tractors with open center systems.
   / Confirm I'm doing it right. Adding 3 spool for remotes #17
Some of this has been addressed already but I'm going to hit it again as part of one big answer
So yes it's a hard line that goes from the loader valve back to the remote/auxiliary valve at the rear. As such I don't see how to put my valve between the 2. (As much as I like that idea. )
I suppose technically I could completely remove that hard line, go directly from the loader valve to my new valve, and then run another new line to the in port on the remote/auxiliary valve.
But that raises lots of challenges as there's not much space at both ends of that hard line. (At the loader valve it comes off at a 90 to go back. ) not to mention figuring out what that threading is where it connects to the valve. I'll see if I can dig up info on the loader valve later on today.
On our CK35 the hard line from the FEL valve terminates into the rear end housing of the tractor but the remotes bolt up the same to a proprietary mating surface on the side of the rear end housing - so they're getting their flow from internal to the tractor instead of directly from the hard line like yours, however the process for replacing the hard line with 2 rubber lines is the same (and actually pretty easy)
I "split" this line (replaced it) to install a solenoid valve to act as a 3rd function on the FEL for a grapple. In that configuration there is no PB port (just P, T, and 2 work ports). All flow exiting one side of the valve is dumped downstream through the T port to the next "thing" in series and when the solenoid valve is not in operation, full system pressure goes in P, through the block, and out T to the rear of the tractor.
In my case that's alright because all the ports are milled in the same aluminum block so all of them can withstand the same pressure, however generally speaking T returns flow at a reduced pressure whereas PB is still full system operating pressure and you should verify your valve can be configured to operate this way, otherwise you are correct in that you will need to also somehow plumb the T port back to a tank line (which the best I can figure due to kioti's proprietary mounting of these rear SCV's - would be all the way up front on the FEL valve) and the PB port back to your factory rear remote.
As to the fittings / threads on the hard line, I'm willing to bet the FEL valve side is the same as ours, in which case it's a banjo type head on the hard line with a thru bolt into the valve body and it's 18mm metric.
Get an 18mm Male to 1/2" JIC Male 90* fitting and screw into the valve and that gets you pointed rearward quick & in little space. After that the hydraulic shop can match whatever is on the other end on your factory rear spool. Get an adapter for that to 1/2 JIC Male then get all the hoses with 1/2" JIC female and you won't need to worry about any twists routing the hose or adding swivels to tighten everything up good.
I have attached the write-up I did on our 3rd function valve. While it's not exactly the same thing, it holds a lot of basic similarities to what you want to do, so it might be some good reading for you.
Best of luck whatever way you decide to go.
  • 3rd function build - Revised.pdf
Thanks N2DFire! Great write-up. For some reason I didn't get notified that you'd posted up so I'm only seeing this now.
I pulled my seat up as I couldn't remember accurately how things looked there since it's been years since I added the rear remote. The one interesting thing I noted (see picture below) is that at the base of the hydraulic filler tube there's a line that T's into it, following that line back it's off the valve for the power steering. (Tank dump) I'm not sure why Kioti did that given there's a large diameter hardline return that feeds to the one side of the hydraulic filter that everything else that has a dump to tank feeds into. But that raises a question from me - Can I T into this return line for my dump to tank from my new valve? It sure would make my life easy if that's the case! In the pic below my finger on the left side is pointing to said return line.
My thought regarding how to hook the new valve up would be to disconnect the hardline going to the 3pt (see above pic, my finger on the right side of the pic.) given the distance that hardline is traveling I'm hoping I can convince it to move over a tiny bit, connect a line from it to the new valve and then connect a line from the PB on the new valve back to where the hardline connected to the 3pt. Doing it this way saves me some of the hassles N2Dfire experienced trying to connect up to the output on the loader valve. My tractor has even less space to play with than his has!
The only big question is are my connections the same size as a Kioti CK35.... Hmmm!
E.
   / Confirm I'm doing it right. Adding 3 spool for remotes #19
E.
Between the dirt and the finger, I can't be 100% sure :D but the one on the right looks like the banjo style fittings.
Our tractor is on "the farm" at my parents place and I'm 95% sure I wrapped the hard line up and stashed it out in the barn someplace but if I get a chance this weekend I'll try to go dig it up and take a picture or two for reference.
If it is that style - finding something to go back into the rear end housing should be pretty easy but getting something to connect up to the hard line might be . . . interesting.
If I think about it (and it's not raining & wet everywhere) I'll try to get better shots of the fitting on the loader valve and stick a ruler in there for scale. It's definitely tight but getting rid of that NPT swivel fitting & adapter and going to JIC made a HUGE difference.
As for the Tank line - if it's like I'm picturing it in my head, you probably can T into that return line - I'll try and look at ours and see if it's the same also.
Well by bad luck I was forced to go to the dealer. Went to use the tractor and the bucket couldn't roll back. Pulled things apart a small joint that connects the cable for the joystick had broken where it connects to the valve. So that's ordered.
Asked the guy there what he thought about tying into that steering return line - he didn't see that as a problem.
Regarding hooking up to the hardline - I'm thinking I'll take the fitting that goes between the hardline and the body at the rear and leave it on the hardline, then it should be easier to find something to connect up to the other end of that fitting.
E.
2017 Ram 4500 Bucket Truck (A52128)
2017 Ram 4500...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
