Condensation problem
   / Condensation problem #1
sros990
West Virginia
JD 990
I have a metal clad pole building, rigid insulation in roof and walls, and a gravel floor. There is so much condensation in the building that you can see water drip from the roof.
What is the best way to eliminate or reducce the condensation?
Thanks,
Steve
   / Condensation problem #2
Usually there is a vapor barrier between the insulation and the metal roofing/siding. If not than you should be able to pick up some 8 mil or thicker poly and cover all the rigid insulation. This is the same stuff that you use to cover unfaced insulation in ceilings.
It is just that, a "Vapor Barrier" so it should take care of any condensation. I have never had a metal insulated building, but this is the way I would handle it, there may be better ways.
   / Condensation problem #3
My shop is built on a concrete slab, metal roof, and insulated well. I put a 6mil poly vapor barrier beneath the slab. Zero condensation from the roof with that portion of the building.
I have a 18' x40' dropshed across the front, 20'x40' across the back, and 24'x24' dropsheds at each end. When the humidity is high it's almost like sprinkling rain beneath these dropsheds. I think this problem is created by the open air circulation beneath the metal roof for the sheds bringing moisture laden air to create the condensation on the metal.
In your case the moisture is probably coming from the soil beneath your floor. You might try scraping it back and putting down a vapor barrier, then put your gravel back over it.
   / Condensation problem #4
We have many steel pole barns in this area where it rains inside from the roof. The moisture comes from the air and condednses on the cold metal just like a coke can fresh out of the fridge.
As long as you have air exposure and cold metal you will have condensation. The ambient outside air here sits in the 90% humidy range.
What folks do is prevent the cold metal from contacting the air by use of insulation that also seals with a vapor barrier. No exposed metal, no raining roof.
   / Condensation problem #5
In my sawmill house i stretched old (Light) tarpaulin over the rafters before putting up the corrugated iron roof. It works fine, the layer of air between the tin roof and the tarpaulin prevents the humidity from condencing, never one drop of water inside the building.
You could brobably insolate the inside of the roof with a very thin layer af any insolation, to prevent the humidity from condensing on the cold, hard surface of your ceiling.
   / Condensation problem #6
I have a question that someone may be able to answer. In my pole barn I have areas of smooth concrete floor and areas of very rough broom textured concrete floor. Only the smooth floor sweats, why?
   / Condensation problem #7
Could be a couple of things. Vapor barrier under the dry side, free draining gravel under the dry side, concrete with a permeability modifier added. Even thicker concrete on the dry side. The finish should have nothing to do with it except the smooth surface will make the sweat more visible.
   / Condensation problem #8
Surface! The broom textured part has a much bigger surface, which enables the surface to pick up heat from the room, so the humid air wont condence against it.
   / Condensation problem #10
I think you have to cover the floor with something carpet like. or seal the building better so the humid outside air dont get that much access.
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
