Concrete slab
/ Concrete slab #41
The plastic is a good idea. Lots of contractors just do the same thing for years and never learn any better. Waterproofing in the concrete is OK but good plastic is not permeable and the slab will not be wet. I have seen lots of slabs wet with condensation around here (South Central Oklahoma) when humidity is high due to contribution comeing through the slab. I have a basement and have taped plastic to the outer walls down near the floor and on the floor and left it for a week. When removed not only was there no condensation ( a frequent happening with unprotected slabs) but the concrete was not even discolored a bit which would have indicated some wicking moisture. The floor is on top of a layer of plastic, 2 inches of rigid foam (R-11) and washed gravel. If you intend to heat the space, consider putting insulation under the slab. If moisture wicks up through the slab from earth contact but evaporates as fast as it wicks you don't notice but on a humid day you can get condensation on the surface. The water coming through the slab can contribute to this problem. Tape down a piece of plastic to the slab for a few days and then remove. If there is liquid water or at least some darkening of the concrete, there is water coming in through the slab and visible condensaton on the slurface is not ALL from the air. The water coming through the slab raises the relative humidity in the space, promotes rust, mildew, sweating on the part of occupants, and such. Don't use just any vapor barrier. Get a good one. It is about impossible to change it after the slab is poured. I used STEGO Wrap and a special HD seam tape but I wanted to be RADON proof as well as protected from moisture.------------ Pat
/ Concrete slab #42
Ergon - if rolled plastic is not the best, what is?
/ Concrete slab #43
Sorry, that's a question I cannot answere. The son was going to tell me but I would have forgot by today.
Damp proof membranes
A damp-proof membrane (dpm) should be laid out before placing the concrete. There are numerous membranes available to suit a variety of requirements. Builders' merchants normally carry 'visqueen' or PIFA 1200 as an off-the-shelf product, as it is much used throughout the construction industry. The purpose of the dpm is two-fold: Firstly, to protect the underside of the slab from attack by dampness and aggresive salts (such as chlorides) or other chemicals in the sub-base or sub-grade, and damaging the concrete, unseen, from beneath. Secondly, a dpm prevents the newly poured concrete from drying out too quickly (de-watering) because of water absorption by the sub-base or sub-grade, which will adversely affect finished strength and can cause hundreds of tiny surface cracks.
Any 'laps' required in the membrane should overlap by at least 350mm, and preferably be taped down to prevent ingress of ground water or egress of mix water.
Just a little more info from Google. Note the stament on various membranes.
/ Concrete slab #44
Most structural engineers, building inspectors and contractors do not comply with the published building codes that require minimum slab thicknesses & specific placement of the reinforcing steel. These standards apply to "structural slabs" which are defined as slabs that contain reinforcing steel AND support or transfer loads. Therefore, slabs that bear traffic or weight (e.g. driveways, garage floors, warehouse floors, sidewalk/drive approaches, ANY building slab, etc.) are structural slabs.
The American Concrete Institute (ACI) 318-11 (2011), section 7.7.1 specifies certain slab thickness (dependent upon the thickness of the reinforcement used). It specifies 3 INCHES of concrete between the earth side (regardless if it is soil, sand, gravel, rock or protected by plastic) and 1.5 inches of top coverage - #5 bars (5/8 inch) and smaller, and 2 inches of coverage for #6 - #18 bars (3/4 inch - 2.25 inch).
Remember when determining slab thickness that the bars cross each other - resulting in steel TWICE as thick as a single bar.
Therefore, if you are using #4 bars as reinforcement in your slab, you would have a minimum 5.5 inch slab (3 inches + 0.5 inch steel + 0.5 inch steel + 1.5 inches). Using wire mush is difficult, as you cannot maintain the required placement of the reinforcement within the slab - it bends & deforms too much.
Contractors are NOT ALLOWED to place the reinforcement on the grade and "hook" (lift the reinforcement into the slab with a hay hook) as they place the cement. They walk through the wet cement, pushing the reinforcement back to the bottom where it does absolutely NOTHING. Additionally, hooking frequently pierces the vapor barrier, rendering it useless.
Don't say that the ACI standards do not apply to your locale - the ACI Standards are incorporated DIRECTLY into the Uniform Building Code (IBC). Every state (except Michigan) has adopted the IBC as their base building standard (IBC 1901.2 "Plain and reinforced concrete. Structural concrete shall be designed and constructed in accordance with the requirements of this chapter and ACI 318..."). California has the CA Building Code, which is based on the IBC ( as usual, CA just made their code more stringent). A number of other states have done the same to meet regional issues (CO - wild fire protection, FL - Hurricanes & Winds, etc.).
The concrete blocks or "chairs" must not be space so far apart, that they allow for the reinforcing steel to deflect (bow or bend) during concrete placement or as the finishers walk on it. ACI 318-11 7.5.1 states "Reinforcing steel shall be accurately placed and adequately supported before concrete is placed, and shall be secured against displacement within tolerances..." IBC R506.2.4 states "Reinforcement support. Where provided in slabs on ground, reinforcement shall be supported to remain in place from the center to upper one third of the slab for the duration of the concrete placement.".
The plastic placed under a slab is known as a VAPOR RETARDER. It's sole purpose is to prevent capillary action (wicking of moisture) through the slab if it was allowed to remain in direct contact with the soil. Care must be taken to adequately overlap the plastic sheets, seal the seams with waterproof tape and prevent the plastic from punctures. Penetrations (pipes, conduits, vents, etc.) through the plastic sheet must be sealed with special cone shaped plastic sheets similar to roof jacks. Notice that the code said "retarder," not "preventer" or "barrier." Some will allow moisture transmission as they may decay over time.
Sand or soil is sometimes placed atop the plastic to absorb the bleed water on the bottom of the slab. The surface of slabs poured directly on plastic will bleed a lot surface water. The perimeter slabs must be elevated to account for the thickness of this material. The support chairs should sit on this material or be of an extended height to allow for it. In some areas of the country, these membranes perform multiple tasks, and are installed to also prevent methane or radon gas transmission into the living space. These membranes are made of special materials, require special seam treatments and incorporate under slab venting. Some systems utilize multiple layers of barriers to achieve the required protection.
IBC 2012 R506.2.3 states "Vapor retarder. A 6-mil (0.006 inch; 152 オm) polyethylene or approved vapor retarder with joints lapped not less than 6 inches (152 mm) shall be placed between the concrete floor slab and the base course or the prepared subgrade where no base course exists.
Exception: The vapor retarder may be omitted:
1. From garages, utility buildings and other unheated accessory structures.
2. For unheated storage rooms having an area of less than 70 square feet (6.5 m2) and carports.
3. From driveways, walks, patios and other flatwork not likely to be enclosed and heated at a later date.
4. Where approved by the building official, based on local site conditions."
The IBC also requires that the earth around the foundation fall away 6" in the first 10 feet, to promote positive site drainage away from the foundation. This also helps prevent water from flowing back under the slab, saturating the base material and causing wicking.
"Turndown" footings can also be added to a flat slab to reinforce the edges, transfer loads and to act as a "cut off wall" for ground water intrusion. These are already incorporated into building foundations as part of the designed load transfer.
Though the codes specify 2,500 PSI as the minimum strength for concrete foundations, there is little added cost and great benefits from increased, strength, durability, wear and reduced permeability in utilizing 5,000+ PSI concrete. Remember, larger aggregate equates to stronger concrete. Most contractors utilize 3/8" aggregate in concrete, because the cost of pumping is lower. 3/4" rock is preferred (and is specified by most State Highway Departments) and yields higher compressive strengths as well. The few thousand dollars extra for a 3/4" 5,000+ PSI mix and a 3/4" concrete pump is worth the return on your investment.
The last point, is that most contractors do not understand "concrete science." Water makes concrete weaker, by creating microscopic voids in the matrix of the concrete (when the water evaporates, it leaves a honeycomb behind - weakening the concrete). Concrete only needs enough water to hydrate the cement particles. There are "water reducers" and other admixes that can reduce the ACTUAL water content required, INCREASING THE STRENGTH and maintaining the flowability and workability of the plastic concrete. If your concrete contractor or ready-mix supplier does not know about these, find someone else (they have been around for decades!).
And above all, DO NOT let the concrete pump operator or cement truck driver add water when the truck arrives at the job site - they just weakened your cement, adultering the formulation and mix design! They are truck drivers and pump operators for a reason... because they are not engineers or concrete/building experts.
/ Concrete slab #45
(And above all, DO NOT let the concrete pump operator or cement truck driver add water when the truck arrives at the job site - they just weakened your cement, adultering the formulation and mix design! They are truck drivers and pump operators for a reason... because they are not engineers or concrete/building experts.)
But the experienced ones sure know how to get through the slump test or get the concrete out of the truck.:thumbsup:
/ Concrete slab #46
Around here, the readimix trucks bring mud that is quite stiff (2-3" slump) to minimize spills coming up
hills. That's a real problem when full. If the mix design calls for a 5" slump at the site, you have to add
water.
/ Concrete slab #47
Well, I agree in principle with not adding water, but... when you order 10 cy of 3000 psi at a 5" slump (about the most common stuff you will see) and it arrives at a 3" slump you certainly add water (1 gal/cy/inch of slump you want).
Its not at all unusual to order a 5" and get a 2". What's worse is ordering a 1" or 2" for curb and getting a 4-5".....
Concrete is not rocket science. Compacted subgrade, WWF, rebar. I don't put faith in visqueen doing much. The issue with water is lazy guys pouring at 7" or 8"+ slumps, there is no need for flat work, nothing fun about pulling 3" or 4" mud but a 5" wont kill you.
BTW last job I did, ordered/specced 3000 psi, test cylinders routinely broke at 4000-5000 at 7 days.
About inspectors and wire chairs, I'm an inspector and I prefer brick, rock, or even wire rebar chairs, I think the plastic cone wire chairs leave a void
/ Concrete slab #48
When I was in the ICF business, I would tell the engineer to spec all concrete at 2500psi, even if the actual
pours would be 3000psi or better. That way, no special inspection and cylinder tests would be required. Of
course, I am talking residential, not commercial buildings.
I have always been a little leary of the accuracy of cyl tests cuz they do not accurately reflect the pour:
samples fully hydrate in sealed plastic cylinders while the slab is often uncovered and allowed to dry out
in just a day or two, sometimes in hot, direct sun.
/ Concrete slab #50
Okay went through this entire thread. I have a two car detached garage cut into a hill in the PNW. Lots of ground water, rain, but soil does drain pretty well. My slab in the winter usually, gets moist to downright wet patches throughout. It is not a leak from above or coming in from the sides! Puddles throughout and isolated. Pad seems to just get saturated in spots. The garage was built on a slab so no footings. Does seem that some 5/8in crushed was put around the perimeter but no drain pipe. I am guessing no vapor barrier.
My Question: Do you think digging a trench around and below the slab level and using perforated pipe and backfill of gravel will help the problem? How much lower do I need to put drainpipe than the slab?
/ Concrete slab #51
No water is coming up and through your slab to form puddles or wet spots unless the slab is below grade and the moisture is coming in from the sides like in a basement. If your slab is above grade, on top of the soil, then even if it is sitting in standing water, the capillary action of water in concrete is still not enough to get through a slab. Even a cracked slab will remain dry on top when sitting in water.
You have condensation forming on the floor. You either need to increase air flow, insulate the walls and ceiling better or raise the temperature inside the building so the air can absorb more of the moisture.
Eddie
/ Concrete slab #52
Eddie
Slab is sort of below grade on two sides. Not directly but very close. It is located on a hill and I have read all of your posts and others on the subject but still feel that there is some hydraulic action going on. So... leaving that argument aside, do you think better drainage around the two high sides will help? I will look into better ventilation but when the air is around 90% humidity here in the NW not much I can do to dry it out. That said, I haven't had this problem before and my current neighbors don't have this problem so I am not buying that it is just sweating from above. I agree with your remedies though.
/ Concrete slab #53
Yes, drainage is very important and the faster you can get the water away from the building, the better off you will be. I'm not a fan of using pipes or French drains, but will if that's the only option. If you can't dig a ditch, then go with the biggest pipe you can.
Eddie
