Compressor for a shop
/ Compressor for a shop #41
To those of you that might be considering a solenoid valve tied to the lights to shut off the compressed air lines when not being used: Consider a "motorized ball valve" instead. The MBV will open or close, then needs no further electricity to maintain either position. A NC solenoid valve needs to be energized constantly to remain open. In the case of turning on the air with the lights, you need a NC valve. Energizing the lights energizes the valve, of course.
MBVs are available reasonably from EBay for sure, probably Amazon.
I will be changing my valve type. My guess is a better air flow path as well. Excellent advice as on occasions the solenoid can develop a 60 cycle buzz.
One question though, how would the ball valve power to close?
/ Compressor for a shop #42
Some MBVs have "power to open" and a capacitor that charges while energized that closes the valve upon de-energization. (2-wire)
Others (3-wire) have a continuous hot to the valve and an additional "activate" wire. Mine uses the first system--capacitor close.
In addition, I have an underground line to the house (1/2" Nylon air brake tubing) that connects to the remote shop system. The MBV in the shop is wired thru a wifi switch, so I can turn the air on to the basement without going out to the shop. The wifi switch has a manual button on it also, so it can be turned on and off locally, without my phone and/or wifi.
I have another wifi switch to control the block heater on my tractor, so I can heat the engine without going out to the shop to plug it in.
EDIT: Cripes! The price sure went up lately. Seems I paid around $40-50
/ Compressor for a shop #43
How long does it have to be energized to charge the capacitor sufficiently to close the valve? If I went out to the shop and turned the light on for say 60 seconds, would the capacitor charge sufficiently to close the valve?
Thanks for posting this Ipakiz!
Gregg
/ Compressor for a shop #44
It charges almost instantly. I can activate and deactivate mine as fast as I can push the button.
/ Compressor for a shop #45
They do make motorized ball valves that Power open and spring return to close
/ Compressor for a shop #46
I've used the same speed aire timed drain since 1995.
Upright compressor mounted on pads with flexline to dryer and flexline out to 300' all copper L pipe with regulator drips and moisture trap which has no moisture.
Rollair is brand of last 2 portables bought... spoke to owner... he took my call and I said OK and bought plus 3 more later for friends.
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
3098 (A63117)
3098 (A63117)
2013 MAC LTT 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2013 MAC LTT 150...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
