Compressor for a shop
/ Compressor for a shop #21
Only set the compressor for the pressure you need. Don't get something compressing to 175psi if you only need 100psi. Lots of wasted energy & CFM doing unnecessary work.
I'm not sure what type of work you do with your air but I "need" 80 psi for my truck tires and if the take is at 100 psi it will be slllloooooowwwww to get meaningful amounts of pressure into the tires because of the small percentage of pressure differential/line friction/valve restrictions. ~125 seems to be as low as I want to do work with for most tasks but I prefer higher so tweak the settings a bit to try to keep it 125+. I'd love a 60 gallon 175 unit, some day, I commonly run out of air with my 20 gal 5.5 cfm IR even though I otherwise love that compressor compared to the old dewalt 10 gallon I'd run for the 12 previous years:ROFLMAO:
One thing I learned after I went to the IR was how much you can do with pneumatics, it's way more than just for nailguns.
/ Compressor for a shop #22
I simply added a power switch with pilot light by the man door, that turns system on when needed. Then added a manual shut off valve at tank next to the air dryer. I personally have no need to keep system pressurized so i dont. If i know i will be needing air, i simply flip on switch as i enter building.
/ Compressor for a shop #23
I like my 80 gal dewalt compressor. It runs my plasma table well and anything else I request of it. I have it plumbed to a filter board that can do dry or oiled air. I like the pex ideas I've been seeing, I will be going that route to plumb the metal and wood shops though. Thanks guys!
/ Compressor for a shop #24
It is vitally important to drain the Receiver often. Not a pleasant thought of having this bomb explode as many have due to corrosion. Check on Google for live explosions.
Sadly one cannot purchase replacement tanks even from Campbell Hausfield.
An upright takes less room, CFM's are important and are rated at 100 PSI. Spray guns require 90. Some receivers (Pigs) are dated on a support leg and should be destroyed after expiry date.
A separate outdoor enclosure and auto drain are very desirable as they are noisy.
/ Compressor for a shop #25
What kind of PEX fittings and air dryer/cooler setups are you guys running?
/ Compressor for a shop #26
I have been happy with this one, bit on the small side but quiet.
/ Compressor for a shop #27
I plumbed my shop all the way around with a stub out every 20’ or one per wall, per room, with an adjustable pressure gauge at each outlet. I run 100 psi then adjust the pressure for each tool at the outlets. Each outlet has a quick connect for the hose. I put a coil flex hose on each.
I installed a 90 gal upright, stationary compressor, by locking bolts with vibration absorbing foot pads to the concrete floor, it is noisy when it runs inside. The shop has heat and air conditioning.
The walls and ceilings are sheeted with 10’ flake board, OSB, over the piping, then painted white.
/ Compressor for a shop #28
I was wondering if anyone had a suggestion for setting up an air compressor in a new shop I am doing. I have always used "portable" type compressors with 150-200psi capacity. I do not know a lot about compressors but do have need to be able to fill up large tractor and front end loader type tires with air. I also use "a lot" of air to blow out swather heads and other debris from equipment after field work and my existing compressors run out of air faster than I need so I have to wait for the tank to re fill. Other than that, the smaller portable type compressors usually do fine. What is the difference between two stage compressors and any other advise or experience would be welcomed. I am thinking I would pipe some outlets throughout the shop to be able to hook into different areas with hoses depending on where I am working on the equipment. Not long runs, but maybe 50 feet or so. Thanks in advance for advise.
/ Compressor for a shop #29
I had an upright 6hp Devillbiss oilfree for a lot of years. Rebuilt the compressor head twice. Finally the conecting rods from the motor drive fried and i had to discard the compressor and motor. Still had a 60 gal tank to use. Bought a portable floor model Harbor Fright oilfree 5hp unit. Took the unregulated 150psi output to the old tank. Now I have the small 5 or 6 gallon regulated reserve tank (with compressor) sitting on top of the 60 gal main. I regulate into the tank @ 125 psi to stay within the tank specs. Works fine using a 1/2 inch impact tool. Haven't done any spraying yet.
/ Compressor for a shop #30
Many good comments so I won't add much. I have had many body shops over the years. Now I am a 2 man show. Definitely get a two stage 175 psi and regulate it down. Do not get a 5hp, go with a 7.5hp. It will be the last one you buy. I run the pipe "at least 50ft" before I put a water separator on it, gives the moisture time to condense, more if possible. Refrigerated dryers are best but expensive. I have good luck with Dessicant dryers before the air hose connection. Good luck
/ Compressor for a shop #31
I tied it to the lights simply because I had teenage boys. :) If I look out of the house and see the lights on.... I also put a limit switch on the large bay door as well as a timer on the propane furnace. Door open, no heat. You only get one hour of heat max and the system shuts off or turn the dial again (I have a personal key override). The only addition I would have made in retrospect is a coin operated timer for the furnace.... :)
/ Compressor for a shop #32
What happened to the OP? (spav1)
Here is an idea that may help someone. I have a barn without electricity, but need air. I purchased a 120 gallon used propane tank. My understanding is that they are designed for 250 psi everyday use. Added wheels to move around the floor and plumbing for cut-off valve and air hose quick connector. When I need air, I use my tractor to carry it to the house/garage to recharge periodically. The volume makes it good for most everything but pneumatic tools.
If someone wants a bigger tank, I might suggest adding a similar tank as a reservoir T'ed to the supply line as an auxiliary tank. My barn has 16' eves and I have even considered mounting it high off the ground between roof and wall to preserve floor space. All propane tanks I have encountered have NPT ports on the bottom and top.
/ Compressor for a shop #33
Don't worry about how much pressure a compressor puts out. Almost any compressor will make enough pressure for your needs. Your main concerns should be volume of air the compressor makes, which is measured in cfm. Also, unlike most equipment, it's not good to get an oversized air compressor. You don't want one that turns on, runs for a short time and then turns back off. The compressor needs to run long enough to get the block good and hot so that it burns off excess moisture. I know it's nice to have a lot of air when using the blow gun, but you can accomplish that with tank capacity, not just cfm. Regulators and water filters are nice, but not necessary if you just air tires and use a blow gun. Just know that if you ever run any pneumatic tools you will need both a regulator and water filter.
/ Compressor for a shop #34
Im not a friend of Harbor Freight….but i can arrest to the fact that their $500 air dryer is absolutely amazing. When i got mine years ago it was $349.00. .. loke 10 years ago. Still works great. I have a paper water trap downstream from dryer, and it has NEVER trapped any moisture. Nothing gets past the dryer. I have a cnc plasma table…cant have moisture in line.
/ Compressor for a shop #35
Not particularly cheap but https://www.compressorworld.com/air-tanks & a ton of other places sell them. Manchester tank is probably the OEM for halft the compressor tanks out there.
/ Compressor for a shop #36
Personally I put a 3/4" RapidAir Max kit & some additional parts probably around 7 years ago.
I used 3/4" hydraulic line to go from the compressor to my filter, dryer & regulator manifold on the wall. Cheap at the farm store, flexible & rated to over 2,000psi. Flexible means you can shuffle the compressor around a hair if needed & it also dampens vibrations from the rest of the system. RapidAir parts from the manifold to the rest of my drops.
/ Compressor for a shop #37
My shop was piped for air in type L copper 3/4" line 10+ years ago. now days i would need a 30 year loan to pay for the copper.
/ Compressor for a shop #38
Use copper, iron, or PEX pipe. Never use PVC pipe for air line. It fragments like a grenade when it breaks & is brittle.
Not all 5hp compressors are equal. Many are way over rated. When comparing, look at the CFM they deliver at a standard pressure. To some degree you can also compare amp ratings. Most motors are similar efficiency, so more amps means more power.
I got a good 5hp Quincy with an 80 gallon tank. Cost a fair bit more than a 5hp Quincy at the farm store, but has more power & what not. In all fairness most of the "5hp" 60 or 80 gallon units are good for a lot of home shops & a good deal.
/ Compressor for a shop #39
I have the 60 Gallon 15.4 CFM Quincy and love it. I do a lot of needle scaling and grinding no problem. A little noisy but I'm wearing ear protection anyhow.
/ Compressor for a shop #40
To those of you that might be considering a solenoid valve tied to the lights to shut off the compressed air lines when not being used: Consider a "motorized ball valve" instead. The MBV will open or close, then needs no further electricity to maintain either position. A NC solenoid valve needs to be energized constantly to remain open. In the case of turning on the air with the lights, you need a NC valve. Energizing the lights energizes the valve, of course.
MBVs are available reasonably from EBay for sure, probably Amazon.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2014 FORD F-150 (A65643)
2014 FORD F-150...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
Case IH STX 375 (A64126)
Case IH STX 375...
