Compressor for a shop
/ Compressor for a shop #1
spav1
kubota 6060
I was wondering if anyone had a suggestion for setting up an air compressor in a new shop I am doing. I have always used "portable" type compressors with 150-200psi capacity. I do not know a lot about compressors but do have need to be able to fill up large tractor and front end loader type tires with air. I also use "a lot" of air to blow out swather heads and other debris from equipment after field work and my existing compressors run out of air faster than I need so I have to wait for the tank to re fill. Other than that, the smaller portable type compressors usually do fine. What is the difference between two stage compressors and any other advise or experience would be welcomed. I am thinking I would pipe some outlets throughout the shop to be able to hook into different areas with hoses depending on where I am working on the equipment. Not long runs, but maybe 50 feet or so. Thanks in advance for advise.
/ Compressor for a shop #2
The 5hp 10cfm with 60 gal tank is what i consider minimum for a shop. 2 stage for 175psi. Plumb in an air header with 6-10 drops depending on shop layout. Do NOT use PVC pipe, only black iron or the new plug and play aluminum or PEX kits. Also hang a 50' or 100' hose reel near the roll up door. You may want to include a trans cooler heat exhanger and water separator between pump and tank. Be sure to consider how you plan to drain water from tank
I have a 1" header loop around the perimeter of the shop with 10 drops and a 100' hose reel.. Some drops are dedicated for a blaster cabinet, parts washer, plasma cutter, lathe and mill, etc. Header is fed by a 7.5hp, 20cfm compressor with 80 gal tank with after cooler and water separator. Compressor is outside shop in a small leanto shed on back wall. Leanto contains compressor, cooler, and RPC. Intent is to keep noise outside.
/ Compressor for a shop #3
Noise is important if you have to.be around it all day...
/ Compressor for a shop #4
Use copper, iron, or PEX pipe. Never use PVC pipe for air line. It fragments like a grenade when it breaks & is brittle.
Only set the compressor for the pressure you need. Don't get something compressing to 175psi if you only need 100psi. Lots of wasted energy & CFM doing unnecessary work.
Not all 5hp compressors are equal. Many are way over rated. When comparing, look at the CFM they deliver at a standard pressure. To some degree you can also compare amp ratings. Most motors are similar efficiency, so more amps means more power.
I got a good 5hp Quincy with an 80 gallon tank. Cost a fair bit more than a 5hp Quincy at the farm store, but has more power & what not. In all fairness most of the "5hp" 60 or 80 gallon units are good for a lot of home shops & a good deal.
/ Compressor for a shop #5
Mine is 80 gallon upright, copper piped thru shop. I also have a refrigerated water separator and inline filter to protect my cnc plasma cutter. Have a 50’ self roll hose at each side of shop.
only thingni wish is that i had installed compressor outside shop, but i had to prevent freezing during winter. The noise sucks.
/ Compressor for a shop #6
Only thing to add, is that you might consider an auto drain system. The one I put in the shop at work, opens the tank drain at least once a day for one minute to dump the condensate. It has a timer clock, set to do it once for every hour of operation, or once per day.
The one we installed came from the local NAPA.
/ Compressor for a shop #7
The pressure operation is important, but more important is the cubic feet of air needed to operate tools. Tools such as a rotery cuttoff tool (we always called a whizzer) and other rotory cutting tools can take a lot of cfm.
/ Compressor for a shop #8
I've had a half dozen compressors. Until I bought my jenny compressor, only 10 gallons but it fills up quick, and most importantly, it's whisper quiet. Supplies my air tools just fine with 2 hoses off the outlet and 2 guns running guns. Sure with low capacity it runs a good deal. But you could stand next to it and have a conversation with someone at normal volumes.
/ Compressor for a shop #9
A lot of good comments above. The only thing I can add is use at least 1/2" hose / pipe for your remote runs to maintain PSI & CFM.
/ Compressor for a shop #10
I bought this one last year when on sale for $329 or $349. It runs what I need ok and when the big garage interior is finished I’ll move it there and have my son (sprinkler pipe fitter) plumb it in. It is amazingly quiet. I debated between this one and Harbor Freight quiet model.
/ Compressor for a shop #11
/ Compressor for a shop #12
^ +1 for blowing debris out.
for a compressor: I have a 60 gallon vertical tank and a copper pipe header down the length of my shop. I have a "radiator" next to the compressor to cool the air and drop any water that's in it. There's about 40' of pipe in 2' of horizontal space before it heads to the other end of the shop. I also have a 2' section of 3/4" hydraulic return hose (working psi of 200) to act as a vibration isolator between the tank and the copper pipe attached to the wall of the shop. And a pressure gauge on the copper pipe.
I use 3/4" copper for my main runs and 1/2" drops. I have 25 or 30 feet of hose on my reels and it's to short. I'm going to be replacing it with 50' or maybe a little more. A hose reel next to the roll up door is needed and enough hose on the reel to reach the equipment outside.
An outside shed for the compressor is really nice if you can accommodate one, and an outside hose reel near your equipment as well. I've also seen a compressor in the garage plumbed underground to an outbuilding. Interesting idea but not sure I'd actually want that though.
As other's have stated, never use PVC. I've seen the aftermath of what happens when the PVC pipe fails. I've seen it used for air in industrial settings. It hold air just fine until it doesn't and the result is quite spectacular.
/ Compressor for a shop #13
I'll disagree with this. Pumping to higher pressure adds to capacity. You won't use air at 175, but you get a lot more air regulated down to 100 psi from a 175 tank than you do from a 100 tank.
I have a nice 2-stage 80 gal vertical tank that pumps to 175 made by a local company called C-Aire. Coming right out of the tank I have a regulator set to 100 psi so all the lines are pressurized to that. I can run air tools like ROS sanders and the compressor can keep up OK, and those things take 15-25 cfm of air at 90 psi. The noise is an issue but where I keep it in one side of the shop (sort of split in half), I don't hear it too bad if I am in the other side. If I am using it heavy for the ROS or working on the side where it is then I have hearing protection on anyways. I leave my tank pressurized all the time and drain daily. I shut off the power and close the outlet valve when done for the day.
Another vote for never using PVC for lines. I'll add copper to the mix, which is what i did. Grade L is suitable for this. Can be spendy but works quite well and easier to install than iron pipe a lot of times.
/ Compressor for a shop #14
My brother bought some aluminum tubing made for compressor lines. It was shielded in blue plastic. Dad and I ran it and put connectors by all 4 doors. It came in a roll like copper. Had compression fittings with it.
/ Compressor for a shop #15
The maintenance guy at my last job plumbed the whole shop air with grey schedule 80 pvc. After the 3rd or 4th blowout, the boss made him pull it all out and replace with iron. It was a big shop with multiple buildings so there was a lot of it.
Rather than throwing it in the dumpster, I told him to throw it in my pickup. It worked great as conduit for the wiring of my pole barn. I still have a big pile of it out back, mostly 1” and 1/2”
/ Compressor for a shop #16
I'll agree with both of you. Compressing air is a ridiculously inefficient process, and the higher the pressure, the less efficient it becomes... and the harder the compressor has to work.
That said, it sure is nice to have as much air as you need, whenever you need it! 👍
/ Compressor for a shop #17
^ +1 - My compressor is capable of 155 psi, I use air at 100 psi, I have my compressor to cut in at 105 and cutout at 140 psi. I don't want to stress the compressor to much, but want plenty of air when I want it. I leave my system pressurized at all times.
/ Compressor for a shop #18
When you install the lines, put them all on a very slight slope with one low point. Put a drain plug at the low point to drain the water when finished.
After installation, jack up the pressure a bit higher than what you would use and turn everything off. Go around and listen for leaks. As stated, compressed air is very inefficient and therefore expensive. If saving money isn't important, the compressor will run a lot less if all the fittings are air-tight.
I worked in a factory that went through and fixed all the leaks. They found that they didn't need the 110 psi it was set for and reduced it to 90. That saved about 6k / month if I remember right. Not a perfect example but it's all relative.
/ Compressor for a shop #19
I shared this a while back and will post it here again. My shop has a 5HP 60 gallon single stage compressor. I went with a SS because I wanted the CFM over time for whatever I may wish such as painting or sandblasting. I think the key to making an informed purchase is to know what you need. Do not buy more than you need in CFM as well as pressure. Storing a lot of air in a tank due to the higher pressure of a two stage compressor also has the sometimes negative affect of not giving you what you want in CFM when you have exhausted that "reservoir". If you do select a two stage and then regulate it down to say 110 PSI, be sure to add a safety blow off should you have any cord reels or drop hoses not rated for the full capacity of the two stage compressor.
I too clean out hay equipment but I do it with a 1HP portable compressor. Yes it runs a lot but I do not want the mess anywhere near my shop so I do it remotely.
I added a solenoid valve to the discharge at the tank on my compressor that only opens when the shop lights are on. I do not fear blowing a cord reel hose or yellow drop line at the lathe or mill. Additionally, when I come into the shop and turn the lights on I can tell when I have a leak because I can hear the overhead steel piping and drop cords fill. In fact, I went into the shop yesterday and turned the lights on and I heard the system fill. I looked around for a leak and found a small break at the end of the cord reel and repaired it. I am appreciative of the fact that if it had blown in the middle of the night the solenoid valve would have protected the compressor from burning itself up.
Gregg
/ Compressor for a shop #20
Unfortunately it seems Northern Tool may have discontinued the unit I bought recently but the super quiet feature is great. You can stand next to it and have a conversation. Mine is 120 volt, about 20 gallons and made in Taiwan. I compared it to the similar HF model and it is much better built.
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2025 LandHonor MGB-72-44W Rotating Grapple Skid Steer Attachment (A61572)
2025 LandHonor...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
