Compressed Air Line Question
/ Compressed Air Line Question #21
Instead of standard schedule 40 PVC you could use schedule 80 if you can find it. I made a couple of air tanks for my truck from 4" schedule 80 PVC and they've been going for some years now.
/ Compressed Air Line Question #22
PVC get's it's rating at a certain temp., with NO impacts...
If the temp changes or if anything has bumped the PVC, the rating also changes and NOT for the good. I'd NEVER use it.
All of my piping in my shops, now and in the past, I've run blk. pipe. It's easy to do and it's a "do it once and forget it" job!!
SR
/ Compressed Air Line Question #23
[video]http://www.hoseandfittingsetc.com/our-blog/bid/94802/what-type-of-pipe-should-i-use-for-my-air-compressor[/video]
Some basic information. It seems there is also aluminum pipe that has been introduced since my "Best Before Date".
/ Compressed Air Line Question #24
After looking at all the choices PEX seems like it has many advantages.
PEX should work..
Do NOT use PEX made for water. PEX does not like a good many oils. It starts a slow breakdown process.
there is PEX-Al-PEX made for compressed air too. More expensive though. .
Yeah, that's because it's not the same stuff!
I plan to run 3/4" Schedule 80 PVC underground for about 200 feet, so I can have compressed air back where I do my wood splitting, and another underground run up front for cleaning boots. It's not going to get hot 2 feet underground, and I'll use copper to the surface. I don't expect any problems with that. If it blows, nobody gets hurt.
/ Compressed Air Line Question #25
I don't like doing jobs twice, thankyouverymuch! I use blk. pipe, so I KNOW I won't have to re-do it...
SR
/ Compressed Air Line Question #26
Try to get bell end pipe . 3/4 in pvc Schedule 40 is rated for 440 psi .
When I blow out irrigation systems we are using a 125 cfm compressor at 100 psi , blowing into thin wall pvc . In 30 years we have never blown a pipe apart , Maybe a couple fittings blew out , but never the pipe itself .
/ Compressed Air Line Question #27
I have a 200 ft run of pvc air line to an out building , then it transitions to copper . It has been under constant pressure going on about 20 years . And its thin wall sdr 21 pvc its rated for 220 psi ( I am an irrigation contractor ) .
No way, bro, it blows up because I heard it from the special air line pipe commercial.
/ Compressed Air Line Question #28
You actually make me wonder how much of the idea that PVCs gonna blow up and kill you stuff is just hype from mfgrs of alternatives.
/ Compressed Air Line Question #30
Ok, so once. It's happened once. I think more compressors have blown up. I know more air tanks have ruptured just from stories on here.
/ Compressed Air Line Question #31
I've seen a couple compressor tanks start leaking, but I've never seen one blow up and fire missiles of plastic shards all over the shop.
You may not care about the folks in your shop, but from time to time, kids and neighbors walk into my shop and I don't need one of them loosing an eye or much worse!
SR
/ Compressed Air Line Question #32
You want to have drains on your low points, for condensate, in air lines.
If you use anything flexible, it creates the likely possibility, that there will be bellies you can't drain.
Rigid pipe allows you to easily maintain slopes to your drains.
Do not use PVC. The pressure rating is for water, not air. Yes, there is a big difference.
Some people have not had an issue using PVC for air. That does not disprove the fact, that it is proven unsafe.
When it comes to air, and air compressors, bigger is always better. Don't run a lot of skinny pipe.
The rigid aluminum, steel, or copper lines are the best choices.
Steel can be bought in most lengths at the big box stores.
But, if you still need some pieces threaded, and don't have a pipe threader, the big box stores usually do that. As well as any hardware store.
Having a drier at the compressor is ideal. However, there are lots of tricks to help keep the condensed water out of your tools, if you don't.
Running the main lines high, with the drops, coming off the top of them, before coming down the wall. As well as, having the drop continue down past the hose attachment, to a drain, are good practices.
Water traps only work on water that has condensed. And, are unnecessary if you set up the lines properly. Water vapor goes right through water traps. Which is why you still get water, even with a $100 trap.
A drier, is the only way to completely eliminate moisture issues.
/ Compressed Air Line Question #33
At work everything is copper with brazed joints... 95% is copper K pipe wall and 5% is copper L
I work at a hospital and did some of the install in 1995 and zero issues.
The lines all have a nice slope and drop legs...
Some equipment is moisture sensitive so I did install a dryer a few months in because we were on the boarder for moisture... since the dryer went in along with an automatic tank drain valve no detectable moisture when sampled.
/ Compressed Air Line Question #34
It's a violation of OSHA requirements because there are numerous cases of explosive failures and injuries. I've seen them written up in various bulletins from state and local code agencies.
/ Compressed Air Line Question #35
I ran 3/4 Rapid air throughout my shop. Really nice stuff, a little spendy though. It's really easy to install and add onto later if needed.
/ Compressed Air Line Question #36
I was tearing out some sch. 40 PVC used on deionized water lines. I would just toss them on the ground from 15' up and that would just shatter the fittings and sometimes the pipe. I know you aren't in a factory setting and more than likely metal won't bang into a pressurized line hard enough to shatter anything, but you never know.
About 20 years ago my brother put a PVC air line in his basement and ran it outside to his garage. After a year he had to change it because it ruptured for some reason.
/ Compressed Air Line Question #37
Tha'ts why I said I will use Schedule 80, not 40. 3/4" is rated at 690 PSI.
That's a 5.5 times safety margin over my system pressure (125 PSI). I think that's probably good enough for an underground run.
Intermittent pressure is a whale of a different animal than constant pressure, and you are only introducing 100 psi into an open pipe, not closing the system and holding 100 psi in the pipe, and your air is cold when it's blowing through that pipe.
/ Compressed Air Line Question #38
Hmmm. I'm wondering if the deionized water may have leached out some of the plasticizers in the PVC, making it brittle. That stuff eats common stainless steel. Industrial fittings that handle it have to be Type 316.
Yep. No way would I run it in a shop or other occupied area.
/ Compressed Air Line Question #39
Hi,
I'm moving soon and will want to run some air lines in my garage and basement. Thinking of putting the compressor in the garage and would like a couple of ports and a hose reel. Then run a line to the basement for some light duty work... airbrush, blowing saw dust etc.
Sounds like you are getting a lot of advice based on what some guys have gotten away with and what's proven to them to be good enough. PVC isn't allowed for the simple fact it's been proven to be dangerous. It might never explode on you, but you really don't know that. It's a gamble that in my opinion isn't worth it.
Since your uses are so limited, if it was me, I would just go with a high quality air hose line. I have two hundred foot hoses that where bought in the 80's that are still working fine. One of them is coiled up on a hose rack outside in the Texas sun every day for well over a decade. I guess hoses go bad, but I've never had one fail on me or wear out so far. Lets say you get 20 years out of a hose, how big of a deal would it be to replace it every two decades?
If you where building a shop and using air tools all the time, I could see the advantages of going with iron pipes or copper, but for just this, I wouldn't spend the money or time to install it.
/ Compressed Air Line Question #40
You keep focusing on the wrong thing, which is pressure. PVC may be pressure-rated but it's not materials-rated for compressed air usage. The compressor oils will start to break down the PVC and it will eventually crack and then break (usually explosively).
Do what you want, it's your life, property and loss. But to get on a public forum and *attempt* to try to rationalize the use of PVC for compressed air systems is a fools errand.
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
Parker Gravity Wagon (A66285)
Parker Gravity...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2023 Blue Diamond 103030 Extreme Duty Cutter (A65640)
2023 Blue Diamond...
Stout Buckets 66-9 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets 66-9...
Cattle Feeder (A65640)
