Completed the hard part of homemade 3rd scv remotes install
   / Completed the hard part of homemade 3rd scv remotes install #21
Can I ask for the size of the fittings you used for front an rear,I used your pic. To make my 4700 work with out 1200.00 kit they want now, I would like to do front an rear connections like your's. Jd won't give me size of fittings, thanks jws64
   / Completed the hard part of homemade 3rd scv remotes install #23
   / Completed the hard part of homemade 3rd scv remotes install #24
On my 4400 the third SCV ports are ISO 6149 female metric o-ring with M18x1.5 threads. The factory kit uses metric to o-ring face seal adapters which mate to the steel hard lines that come in the kit. If I was doing a homebrew kit using hoses rather than hard line, I'd probably get adapters to go to 3/8" JIC. Avoid pipe thread whenever possible IMO.
967-6-18 | 3/8" JIC Male x M18x1.5 Metric Male: DiscountHydraulicHose.com
Looking back at the OP's pics, it appears his unused 3rd SCV is the outer one. On mine it is the inner, the outer two run the loader. I had to disconnect the loader lines to get a wrench on the inner fittings...bit of a pain and less spacious than OP's pics. Check which way yours is configured.
   / Completed the hard part of homemade 3rd scv remotes install #25
Thanks for help! Mine are inside also, I am going to use hoses instead of hard lines. Well send pic. When finished.
2018 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-250...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
UNUSED WOLVERINE SBG-13 72W 83.2" SLIDING (A57193)
UNUSED WOLVERINE...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
