Completed the hard part of homemade 3rd scv remotes install
   / Completed the hard part of homemade 3rd scv remotes install #21
Can I ask for the size of the fittings you used for front an rear,I used your pic. To make my 4700 work with out 1200.00 kit they want now, I would like to do front an rear connections like your's. Jd won't give me size of fittings, thanks jws64
   / Completed the hard part of homemade 3rd scv remotes install #23
   / Completed the hard part of homemade 3rd scv remotes install #24
On my 4400 the third SCV ports are ISO 6149 female metric o-ring with M18x1.5 threads. The factory kit uses metric to o-ring face seal adapters which mate to the steel hard lines that come in the kit. If I was doing a homebrew kit using hoses rather than hard line, I'd probably get adapters to go to 3/8" JIC. Avoid pipe thread whenever possible IMO.
967-6-18 | 3/8" JIC Male x M18x1.5 Metric Male: DiscountHydraulicHose.com
Looking back at the OP's pics, it appears his unused 3rd SCV is the outer one. On mine it is the inner, the outer two run the loader. I had to disconnect the loader lines to get a wrench on the inner fittings...bit of a pain and less spacious than OP's pics. Check which way yours is configured.
   / Completed the hard part of homemade 3rd scv remotes install #25
Thanks for help! Mine are inside also, I am going to use hoses instead of hard lines. Well send pic. When finished.
2012 Dodge Charger Sedan (A55853)
2012 Dodge Charger...
24" EXCAVATOR BUCKET (A52707)
24" EXCAVATOR...
2016 BOMAG BW 177D5 SMOOTH DRUM ROLLER (A52707)
2016 BOMAG BW...
Texaco Antique Fuel Pump Art (A55853)
Texaco Antique...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2007 Ford F-150 Ext. Cab Pickup Truck (A55852)
2007 Ford F-150...
